Electrolux Z23042 upright vacume cleaner, why is the suction not working?
Hi there SmartAlec from NelsonVacuums.com.au here.
There are a couple of common reasons that your electrolux vacuum cleaner would appear to have lost it's suction. The first and most common is that it has actually broken a belt. If the belt is broken the brushes won't spin and it will not pick up dirt. It is easy to test simply turn the vacuum on, release the handle (as if you were about to vacuum carpet) and lift up the head and see if the brushes are spinning. If not i can supply you with a new belt.
If the brushes are spinning then your next most likely cause is that there is a blockage in the vacuum somewhere. Test this by turning machine on and checking the suction at the hose (as if your were going to vacuum the couch) if it is poor then remove hose and fish out blockage. If it is ok you may have a blockage between hose and the brush of the vacuum.
If it is neither of these problems i can trouble shoot over the phone if you live in Australia 0269215200 or by email [email protected]
Happy Vacuuming.. :)
Is the brush roller air driven or or powered? Does the machine turn on, and there's just no suction through the brushes? Check your belts and also for clogs.
