Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
My apex gb5108 convergence lines wont line up.I'm watching 3d
I have a apex gb5108 and i think the convergence board is bad but every tv repair shop i call says they cant get the part. It looks like I'm watching tv in 3d. What can i do to fix the problem or is there a part i can use as a substitute. Please tell me its not junk
Posted by dohc90zc on
Anonymous
    Problem Solver:
  • 6 Answers
Possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Posted on Oct 04, 2009
There is a bow in the picture top and bottom of screen
The tv have a problems known as a convergence problems,it is dead.Tv have colors R,G,B lines mis alignments,have shadows pictures or 3D picture look alike?Yes the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replace on the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
1helpful
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
I have a black line acrossthe center of my apex gb5108 tv. does anyone know if it is worth fixing?
hi
it should be changed just
if any body want to repair, it may be to expand the problem
Come up 3d how to change
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apex gb55108 the convergence is bad ...shows images in 3d form can not set
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Convergence out of line
STKs must not have held up Look in back of set they are 2 Big Black ICs will have part number on them example STK392-110,if 110s use 150s.you can order parts from MATs 1-800-628-1118.
Screen Distorted
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Wavey lines apex 5108 projection tv
The problem can be the convergence board, or a problem with one faulty component on the main pcb.
Here you can find replacements, if you do not find your model in list call them at 1-866-925-PART (7278)
Convergence IC's
Lines going across is a little vague but there is always the problem with the electrolytics (caps) around the vertical, be sure and get the one on the power supply too. Just change all you can find(usually 4-5). Thre are 2 convergence ic's if you didn't change them both, resolder the other one.
Then check the value on R519 for me.
3answers
Convergence and wavey picture problem
Actually you have 3 problems. The two that you listed and the third which is: Apex does not support their units. Ask anyone who has tried to get any service. Your problem sounds like a bad digital convergence box. I fix this problem several times a week but on name brand sets. Cost is usually less than $100 for the part. Some problems with Apex equipment can be fixed if the part is a common off the shelf part. That is not the case with your problem. Apex equipment is cheap for a reason. All posts that I have read say that they do not last long and you can't get parts. That has also been my experience as a technician. We don't even accept Apex units for repair anymore. Next time spend the extra money to buy a name brand unit and it will more than likely be repairable.
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
