Sony KV-32S45 32" TV Logo
Anonymous Posted on Aug 25, 2009
KV-HX32 SONY WEGA TV
TURNS SELF OFF BEFORE PICTURE COMES UP. RED LIGHT FLASHES 10 TIMES
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Aug 25, 2009
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2820452
Points
26282
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Testimonial: "Thank you so much"
  • petawatts200 Mar 06, 2011
    Mine is doing the same thing, Is it worth fixing?
Sony KV-30HS420 stand by light flashes red 7 times
this is a lamp issue please replace the lamp this always happen and best thing is you don't' need a technician to help you yo can do it by your own
Our problem is that the red light flashes 10 times and then it turns off we can hear sound but cannot see a picture we have turned it on with a friend on an outside antenna and it works but through...
If you were able to get it to work with one signal source but not another, the poblem may be with the foxtel cable rather than the tv. Was there a difference between the connection from the aerial antennae and the cable? Have you checked to make sure another tv works on the cable from that location?
3answers
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
Sony drc-mf, 29inch turns on, red light brinks 5 times at intervals
29 inch Sony tv D R C good working but pip & Twoin pics no picture blank plz help me
1helpful
I have wega KV-HR36 red light flashing 10 times
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
1helpful
6helpful
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
