hi. that problem have 3 thing 1- software draver damage 2- build sound card is disable in bios 3- sound card damage
first u need check in bios, look at yr sound card, if disable, change to enable it, second check yr system properties looking for sound driver, if sound driver lost, u need get sound driver for your laptop and install it. lastly, if sound device damage, i suggest u use usb sound device becouse cost to get it is very low ok regards contect me for future problems
You need to buy a separate sound card it is because your onboard sound card was damage and to able to have sound on your computer. Just buy a PCI Sound Card and that is a compatible sound card for your motherboard. To install your sound card on your motherboard follow this steps:
1. Insert the PCI Sound Card in the PCI Slot (White Slot).
2. Turn On your computer and wait if the computer are recognize the device. Then if the dialogue box was appear "Found New Hardware".
3. Insert the CD Driver in your CD-ROM.
4. Click the selection box "Yes, this time only" then click the Next button and read the instruction to finished the installation process.
if you cant hear voice .. then it may happen that your sound driver may got corrupted or sound Card may got damaged. 1st try to update that sound driver and if this problem exists then check for your sound card.
Providing the CD Rom, is the same software as the sound-card.
If the sound card, is a seperate ( Add-On ) the drivers cd should accompany the card. if there are no drivers with the card. you can usually visit the manufacturers website ( Support centre ) And download the Drivers.
Additionally, you may have to disable the on-board sound-card ( Via The Bios ) and instruct the computer to start up, with the required or installed card.
If you are running an operating system, such as Windows XP, it should automatically detect and install the best drivers for the device. although you may not get full functionability.
If you install from CD Rom, ensure the card is installed first, then insert the CD, and open to find the Icon ( setup.exe Or Similar )
Have you install the sound card driver? sometime it came with your motherboard cd. Try to install it first.
If you still got no sound, i think your on board soundcard has been damage. Just buy add on sound card and plug it into your pci slot. and off course install it driver before you try to run the sound/music program.
It happens...
Reinstall the sound card driver ... and it ll be fine again
THe driver must be there in *********** board CD that came along with the computer.
