First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Try installing PC suite once again. also check the drivers for the USb cable.Try plugging any other USB device in your computer. if it doesnt work, then usb port on your computer is bad,.
Be sure the the headset in in 'Pairing' mode. When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
yea how ya goin mate its simple i had one of them, just go in your menu go in your bluetooth setting and search for device but make sure your head set is on and fully charged
