Question about Westinghouse Refrigerators
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
SOURCE: I am looking for a power connector wiring diagram
Some of the mixers have common connectors.
It appears that for the three pin connector, pin 2 is center tap of AC source, and pins 1 and 3 are the ends of the transformer windings.
This is from a schematic of a MX2643A which MAY be similar to yours. One of mine has a 3 pin Amphenol connector with a locking screw ring...
Use this info at your own risk, however, the power inout is easy to trace out to verify. They use a typical bridge rectifier to get plus and minus from the external transformer.
The pin markings on the connector CAN be confusing.
Suggest you use the light bulb trick of putting a small lamp in series with the 120 line as an auto reseting fuse.
Posted on Mar 10, 2010
SOURCE: I am looking for a wiring diagram for the three
Thank you for posting your question here on Fixya.com.
I sent the number to my AOSmith tech contact. I hope to have it monday sometime. Please contact me thru our site, www.arrowmotor.net, so I have your email address to forward the connection diagram to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 13, 2010
SOURCE: could you please supply an
here is the diagram.
note this is a general wiring diagram for westinghouse refridgerators and depending on your model may be there are some small changes
if having problems viewing image , click here
Posted on Oct 09, 2010
SOURCE: looking for westinghouse wiring diagram
I have just removed one of these motors today. The cabinet has the wiring diagram on it. I will be back on site once I find a replacement motor and can get the diagram then.
Any idea what motor replaces this one?
Posted on Dec 21, 2010
Testimonial: "i found a fasco d262 motor on shortys hvac supplys website [www.shortyshvac.com] that will work for me.look for a fasco d151 this may work also "
Sep 28, 2017 | Westinghouse Refrigerators
Jan 10, 2016 | Westinghouse Refrigerators
Dec 04, 2014 | Westinghouse Refrigerators
Jul 31, 2012 | Westinghouse Televison & Video
Feb 02, 2012 | Refrigerators
Sep 06, 2011 | Refrigerators
Dec 20, 2010 | Heating & Cooling
Oct 30, 2017 | Refrigerators
Nov 25, 2009 | Westinghouse Refrigerators
Mar 30, 2008 | Refrigerators
195 people viewed this question
