2007 Pontiac Vibe Logo
Posted on Aug 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 Pontiac Vibe radio LCD light partially dimming on left side. Is this a fuse problem? Cig lighter is OK.
Anonymous
Level 2:
President:
  • Expert 169 Answers
  • Posted on Aug 30, 2009
Anonymous
Expert
Level 2:
President:
Answers
169
Questions
0
Helped
62894
Points
967
The bulb in radoi is bad need to be sent out
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1244
Points
Where is the fuses situtioned for fuel light
Location of radio fuse for 2004 Pontiac vibe
Cig fuse 15 amp location - fuse block instrument panel Fuse Block - Instrument Panel
Left of the steering column, behind the storage compartment.
Pontiac Grand Am interior Fuse
Any fuse that is alive with the key on is ok.
Cigarete lighter will not work fuses do not appear to blown
From the op manual and having done it myself......"the fuse block is located under the instrument panel on the driver side of the vehicle."
Fuse # 7 is for the cig lighter and accessory power outlet.
4helpful
I blew my fuse to my radio and cigarette lighter...where do i find the fuse box?
  • The cigarette lighter fuse is in the fuse panel, under the dash, drivers side.
  • See the diagram I uploaded. The cigarette fuse is marked in red. Third one down and fourth over (from the left).
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Radio won't turn on. Fuse blocks don't identify a radio fuse?
w/out amplifier; dome, and Cig. hint if you cigarette lighter is working and your dome light is working ,the problem is not fuse is the radio.
With amplifier. Amp, Cig, and Dome; again if cigarette lighter and dome light and amp fuse is good then amplifier is bad, or Radio is bad the only hint in this one is that the amplifier control sound if radio has ilumination then the amplifier could be the cause.
All this fuses are located by the lower left side of the steering column.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
1helpful
Where is the inside instrument panel fuse box in a 2005 pontiac vibe? I think I blew the cigarette lighter fuse, which also knocked out my radio.
fuse box is located left of steering column behind storage compartment. fuse #17 15amp is the liter fuse.
What size radio fuse does a 2005 pontiac vibe take and where is it
FUSE VALUE FUSE LABEL FUSEBOX LOCATION 15 AMP "CIG" DRIVER'S SIDE DASH PANEL 15 AMP "DOME" DRIVER'S SIDE UNDER HOOD
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
4answers
2005 vibe radio and cig port stoped working
usually the radio and the cig lighter sharing the same fuse make sure it is the right fuse you looked at i check all the fuses
4helpful
2answers
Radio, Cig Lighter and Clock all stopped Working
The radio, lighter and clock are controlled by 2 fuses:
The 15 Amp CIG and the 15 amp DOME, under the dash, driver side, for a USA car.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
