Question about Heidelberg Office Equipment & Supplies
Sassy Heidelberg telrphone number - Heidelberg Office Equipment & Supplies
Posted by H Bauer on
2answers
Scanning lines
Check this link for a bit of info about the scanner. http://www.hwkb.com/Uwe/Forum.aspx/scanner/973/Heidelberg-Linoscan-1450-sparepart-and-driver-for-Windows I agree: Heidelberg no longer support the model so you will have a lot of trouble finding spares - I searched a lot and the only place you can find these now seems to be e-bay. I would be tempted to say get a new scanner, but it is just possible that replacing the lamp if you could get one or cleaning the inside may help, but a scanner usually only has a few years life in it. Just possible the lamp is standard, if you can get to it and get a part number from it, perhaps we could find one online. Hope this helps :)
2helpful
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
Solutions for "heidelberg windmill" problems
this a topic for vacuum cleaner troubleshooting. And you are talking about the Heidelberg letterpress model T 10x15 , what do you need?
1helpful
My Blaupunkt, Heidelberg CD51 car stereo beeps every minute or so, whether you're listening to the radio or CD's? - HELP please
That normally means that it requires the  security code to be entered.
Disconnect the fuse for 10 minutes, replace then enter the code.
If you do not have the code then the radio will have to be removed from the dashboard and quote all the letters+numbers on any labels, barcodes or stamped in the metal casing.
Also quote the make of car it is fitted into.
2helpful
Instruction Manual for Disney Sassy Pixie
You can download your manual there.
http://digiblue.com/customer-service/downloads/index.html
1helpful
3answers
Heidelberg 2650 Linoscan scanner and XP
Hi - You need to install a driver for XP, you can find it on the following link:
Good Luck!
2answers
Mac OS X software for my Heidelberg 1450 Firewire scanner ???
Try vuescan it say it works with your scanner http://www.hamrick.com/ it costs money but has a free trial
Top Heidelberg Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
