Question about Haier BC112G Wine Cooler
Fridge not getting cold tempture on high number 7 what should we do to get it runing
Posted by loveystubbs on
jasbo
  • 2,239 Answers
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
The fridg part is not cooling? Have turned up cooling to 7 whats next is only three years old?
7 is warmer to get colder turn it down to 3
fridge settings work from high number is warm to very cold 1 freezers work opposite with 1 being warm and 6 = -20c
Dec 13, 2017 | Refrigerators
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
What tempture for fridge setting
38 degrees in fresh food side and 0 on freezer side
Oct 16, 2014 | Waechtersbach Red Ceramic Rimmed 7 Square...
Samsung srs585hdis side by side fridge freezer
The cold control inside the fridge may be defective. Hmmm...wonder why Samsung did not mention that as part of basic troubleshooting? If no adjustment of the cold control yields results, chances are it is defective.
Oct 22, 2013 | Refrigerators
How do i turn the fridge colder,on the thermosat inside is it higher or lower number for colder
turn it higher. if that does not work you need a new thermstat you fridge should be 6 degrees to keep food at a safe tempture hope this helps roxyblue57
Jul 16, 2011 | Refrigerators
Code po116 , tempture guage stays on cold, both fans are runing put 2 thermostes new. possible codes po520 po340
it peobably needs a new coolant temp. sensor thats what the po116 stands for. or it could be loose connector or wire short, but a bad sensor would be a good guess
Mar 20, 2010 | Chevrolet Malibu Cars & Trucks
At first the freezer wasn't freezing and the fridge part was getting cold, now it's reversed, the fridge is not getting cold and the freezer does...It does runs, could it be freon?
Turn the freezing unit down to the lower number,and the fridge compartment up to about 7 or 8.Leave it over night to balance.
Mar 14, 2010 | Refrigerators
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Haier BC112G Wine Cooler Logo
956 people viewed this question
Top Haier Furniture Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
john h
Are you a Haier Furniture Expert? Answer questions, earn points and help others
