Washing Machines Logo
Posted on Aug 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Mah6700. Not filling/ draining simutaneously=NO CYCLE
Maytag Mah6700. Hot water inlet shuts off fine but water drains simutaneously=no fill=no cycle. Cold water flows even when powered down (bad inlet?), but it too, drains simutaneously when on, which results in no fill and no cycle. The water is going right through the washer.
Replaced pressure switch.
The hose from the pressure switch looks great.
The code was showing OE (overfill error) prior to pressure switch, but now won't even start a cycle to display that.
Any help is appreciated.
fixrguy
Level 3:
  • Master 415 Answers
  • Posted on Aug 25, 2009
fixrguy
Master
Level 3:
Answers
415
Questions
0
Helped
82581
Points
1311
Try to blow through the pressure switch hose back into the tub and if you have a piece of same size hose when you disconnect the tube to blow through it use you spare hose connect to the pressure switch and blow lightly do you here a light clicking when you blow into it if not pressure switch is more than likely failed when you done tested air restrictions ........RECONNECT THE TUBE TO THE PRESSURE SWITCH.....
1helpful
MY MAYTAG FRONT LOAD AT TIME WILL FILL WHEN WASHER IS NOT ON OR WILL DRAIN AND SPIN ON IT'S OWN
It may be the water inlet valve is not shutting off the flow 100%. If water keeps trickling in, even dripping, it will eventually fill the drum. Some models have a water level sensor that will run unit thru a drain cycle to prevent an overflow situation. Try checking the unit every 6 or 8 hours to see if there is a slow build up of water accumulation. Replace inlet valve if there is.
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Water overlows from my Maytag Model LAT7304 as it
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
WATER DRAINING
2answers
Maytag mah6700 will not stop filling with water
have you check the pipes to the pressure switch and most have a small venturi in the pressure switch have you replaced that
2answers
1helpful
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
3helpful
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
22helpful
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
