To set the timer on a Mark 49 Culligan water softener to refill the brine tank, you will need to consult the user manual for specific instructions. The manual will provide information on how to set the timer to control the frequency of regeneration cycles, as well as the amount of salt that is added to the brine tank during each cycle. If you no longer have the manual, you can contact Culligan or check their website for a downloadable copy. If the brine tank is not refilling enough after cleaning, it is possible that the brine tank float may be stuck or damaged, or the water level in the brine tank may be set too low.
Either the electric valve has failed, or the line is plugged. Try blowing out the water line first and free it up from buildup and then if it seems unobstructed, check the valve function. Salt crystal buildup is common.
Call Culligan for service. You have a serious problem as it sounds like your resin bed is not going through the backwash cycle before returning to operate mode.
Normally when your water softener goes through a recharge cycle, a solenoid operates to bypass the system while brine (extremely salty water) is drawn into the resin tank to perform the ion exchange process. This is a timed process. Once it completes then your softener switches into backwash mode where the resin bed is flushed with clear water. Finally at the end of the recharge cycle the softner switches back into normal operation.
This is not something that you can fix yourself. Contact Culligan immediately.
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it. RJ
That depends on what part of the cycle water is going into salt tank. If it is the last cycle (refill) it is normal until the proper water level is reached. If it is any other cycle then the brine piston or sealpack needs to be replaced. RJ
If you disassemble the valve completely (all metal parts) the valve itself is delrin plastic and is recyclable along with the brine tank. You may be able to scrap the softener tank. You will have to get all the resin and gravel out of it. Just tip it over take the inlet manifold out and drain the resin into a bucket, take the resin to culligan for disposal. RJ
If the unit will recharge then you might have what is called a salt bridge in the tank. The salt is stuck above the water level in the salt tank. Poor a gallon of water over the top of the salt and see if you can then break it up. The salt should go down then.
The final rinse setting may have moved, which will coincide with the salt/brine draw rate...the Culligan units have a funny way of doing exactly that, which, by the way, can generate a lot of revenue for them, if your on a salt route for them to deliver it to you!....I would look up a qualified and TRUSTWORTHY!!! Culligan repair tech, or a service manual to reset this final rinse.
