Question about Frost Refrigerators
My scan frost freezer is only freezing at the top level but the down level is not freezing both fast freezing and compressor buttons are on but do not know how to set the control on appropriate level.
Posted by Olayemi Omoshalewa on
5 Related Answers
Anonymous
SOURCE: BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Posted on Dec 19, 2007
David Coomer
  • 1073 Answers
SOURCE: Freezer Frost and Too Warm No Ice
replace the defrost heater wr51x10031
Posted on Apr 10, 2008
Anonymous
  • 51 Answers
SOURCE: Freezer building up lots of frost, but on lowest setting.
FREEZERS SHOULD BE TEMP AT O /REFRIGERATOR SHOULD BE 40/FOR PERFECT OPERATION.1ST IS THE FAN RUNNING IN THE FREEZER/IF YES UNPLUG FOR 6-8 HOURS AND RETRY/IF NO UNPLUG THE FRIDGE AND REMOVE THE BACK PANEL OF THE FREEZER MAKE SURE THE FAN IS PLUGGED IN.IF SO PLUG IN THE FRIDGE AND SEE IF THE FAN IS TURNING.IF NOT YOU NEED A NEW FAN IF THE FRIDGE IS NEW MAKE THEM BRING YOU A REPLACEMENT FOR FREE.
Posted on Jan 17, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
Raz Mataz
  • 389 Answers
SOURCE: I have a Norfrost 100ltr chest freezer that is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
All systems clean and running, but freezer too warm and unit runs continuously
what does the frost pattern look like on the evaporator? Is top of the compressor too hot to keep your hand there?
APPLIANCE 911
May 28, 2016 | Frigidaire Refrigerators
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My coolers compressor has a frost build up on it and the temperature is at 50
start with checking the freon level. If too low, the txv will open and try to feed the evap. this can cause some overfeeding and give you some frost in some cases. It could also be a txv not feeding correctly. usually and overfeeding condition. causes frost build up on line and compressor and pressure in evap too high to remove the heat needed to properly cool. If a cap tube system, usually a sign of over charged or a real dirty condenser. In both cases, an evap fan, not properly working will cause a freeze up of the evap causing a high box temp and frost build up on the line and compressor.
Aug 14, 2010 | Nor-Lake KLF7766C Commercial Freezer
Lost vacumn, door popped open alarm on
If is the type of freezer where the shelves are also the evaporator(shelves are very cold and is normal to frost), the fact that only one shelf is iced would indicate the system is low on freon due to a leak. This would also explain the hot walls and compressor. It requires a service man to check the freon level and locate leak and recharge.
Sep 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Apr 25, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
Apr 02, 2008 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
RudeRude
john h
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
