Question about Car Audio & Video
My name is Noah. I have a Volfenhag zx 7150 2 channel amp, and I was wondering if I could use this amp to run my mids and highs. And if yes, how would I run the wiring?
Posted by violentj_1_u on
Anonymous
  • 655 Answers
Hello violentj_1_u,
Yes, the amp can be used to power normal speakers on 2 channels.
The best way to wire the amp to a stock receiver (head unit) is to use a pair of wiring harnesses, one the standard harness that plugs into the vehicle wiring, the other a "reverse" harness that plugs into the stock receiver.
First remove the plug from the receiver and plug in the "reverse" harness. Run the speaker leads from the reverse harness to your amp inputs or to a line output converter (LOC) and RCA's to the amp. Then run the amp speaker outputs to the standard harness speaker wires. Plug the original receiver plug into the standard harness and splice the remaining wires, 12V constant, 12V accessory, ground, illumination, etc, together. Connect the 12V switched wire to your amp remote terminal.
Hope this helps.
Posted on Aug 25, 2009
Lights are on but no bass is being played, went out after it got hot.
Blown High output resistors. Definately repairable. Good luck. If you can solder, try removing the high output resistors, replace them with parts from Fry's. Cheap fix. Good luck. Depending on the size of the amp, there will be about 6-10 of them. Check all channels on the amp.
Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS [email protected] thank you Thomas Anderson
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Best way to connect a 15'' kicker cvr15 4 ohm dvc [single sealed box] and a volfenhag zx-4712 1000w 12'' 4ohm+4ohm dvc to my pyle 885 1000w 4 ch. bridgeable amp and how to wire the voice coils that are in...
best way is to just run the volfenhag with a set of wires for 2 channells(one set per coil) left and right @ 4 ohms per channell. The CVRs you can parallel the coils(2 ohms) and run a set from each sub to the amp in stereo left and right. This will give the kickers a little more juice than the 12 but should be fine.
I have two volfenhag 1000 watts speakers
If you are looking for some serious sound try using a Rockford Fosgate P3001T Amplifier.. it pushes 3000W Max its a 4 channel amplifier. Or you could go with something small. I have two JL Audio 10s in my car running with a 600W 2 Channel MTX Amp.
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
