2000 Volkswagen Beetle Logo
Posted on Aug 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change a 2008 vw beetle headlight bulbs
2008 vw beetle
  • sonnydlc1 Aug 24, 2009
    Is there any simple way to replace headlight bulb for a 2008 VW Beetle other than removing all the parts around the cover (battery ....) It's suckssss. \i guess I just have to drive my car to the dealership
  • Marvin
    Marvin May 11, 2010
    FINISH THE QUESTION PLEASE.
Anonymous
Level 2:
  • Expert 120 Answers
  • Posted on Aug 24, 2009
Anonymous
Expert
Level 2:
Answers
120
Questions
0
Helped
50202
Points
361
Open hood then remove plastic around required lamp then remove wire & bulb clip remove bulb then insert new one and replace clip put cover on again and your done easy.
  • Anonymous Aug 27, 2009
    if you are a gairl get the garage man to put it in or get a girl to do it then he will do it for nothing fo you.
Anonymous
Level 2:
  • Expert 216 Answers
  • Posted on Aug 26, 2009
Anonymous
Expert
Level 2:
Answers
216
Questions
0
Helped
85682
Points
668
These are kinda trickey it fits together into a plastic housing you must pull up on the plastic ribbed arm and it will cause the headlamp assembly to move away from the housing then you nust turn it slowly wiggling it out of the holder then you can replace the bulb.
1 Related Answer
A
Anonymous
  • Posted on Oct 14, 2008
SOURCE: How to remove head light in a 2006 VW Beetle
go here
http://wiki.answers.com/Q/What_is_the_procedure_for_headlamp_removal_on_a_2006_beetle
1helpful
My 2008 VW Beetle Is there room behind the back plastic bumper to the metal bumper structure to take reverse censors, does the bumper have to come off?
WAIT UNTIL YOU NEED A BRAKE LITE BULB OR A HEADLIGHT BULB. YOU HAVE TO TAKE THE BUMPERS OFF TO COMPLETE THESE USUALLY SIMPLE TASK. BEETLES ARE A BEAR TO REPAIR.
2008 VW Beetle: the locking mechanism on the passenger side headlight seems to be missing a plastic piece. What is is called and how do I fix it?
The whole heldlamp assemble is what they call the composite assemble,what part you need are for the carrier,this includes the locking mechanism,8_12_2012_8_30_55_am.jpg
Need to replace driver's side headlight on a 2008 vw beetle
This is not a fun job. The headlight retention system sometimes becomes locked up due to dust and grime on the mechanism. Even if things are clean, it is VERY difficult. Take my word for it, a VW dealer is the best bet for you. The headlamp mounting system on the Beetle is one of the stupidest setups I've came across in 45 years of fixing VW's. And you can bet VW designed it to force you to go to the dealer.
1helpful
How do you change a headlight bulb on a 2007 VW beetle
Hope this helps! Please don't forget to rate. Thanks!
Removal & Installation
  1. Insert a hex wrench into the headlight lock and turn it clockwise 180°.
  2. Turn the wrench back 90°
Headlamp lock—New Beetle
Push the retainer tab to remove the headlight—New Beetle
3. Push the retainer tab and remove the headlight assembly. It will unplug from the connector automatically.
4. Installation is the reverse of removal. Insert the assembly carefully to make sure the connector engages properly.
How do I change the headlight on a 1998 vw Beetle?
Lift the hood and if equipped remove plastic engine cover. On each headlight you will see plastic retaining latches. releasing these latches will allow the whole headlight assembly to slide out. Its a canister type assembly. You can then access teh bulbs to replace the lights. it reassembles teh same way
1helpful
How to change headlight on 2008 vw beatle driverside
the hard part is finding a release clip for the headlight. its usually right on the side of the headlight in the engine compartment in between the barrtey and the headlight. once you release this clip, the whole headlight pops out, the you just replace the bulb and put the headlight right back in and make sure you put the clip back on.
1helpful
2answers
Need to replace 1 headlight bulb & 1 tailight signal bulb
Thank You for contacting Fixya.com.
In order to understand the complete procedure and have some pictorial information about replacing the headlight bulb in a new beetle I would request you to please refer the web site:
Go to this link..... www.newbeetle.org is by far the best place for New Beetle problems. PICTURES AND ALL http://www.newbeetle.org/forums/showthread.php?t=171
and for the tail light I would request you to visit the website :
http://www.ehow.com/how_4554444_light-bulb-vw-beetle-tdi.html
The material available in the websites are detailed explaination along with pictures which if copied in this reply would make it very big and heavey.
Good Luck and God Bless.
3helpful
HEADLIGHT REMOVAL 2008 VW BEETLE
there's a tab on the plastic ring that you need to pop, and then wiggle the whole light assembly out and disconnect the wires
access for the bulbs is a panel you undo at the back of the light assembly, and the low-beam bulb is the first one you encounter when you reach in. (H1 should be the bulb)
putting it back in requires even more wiggling, as you tighten the plastic ring and lock it in place (pay attention that you get the light back in flush to the body work)
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
