Question about Freezers
The top of the freezer is not freezing.
The top of the freezer is refrigerator cold, but not freezing. Could the freezer be too full? Would that be a problem?
Posted by deniseturner on
Anonymous
    Scholar:
  • 66 Answers
Normal 0 If the bottom of the freezer is freezing (but only just), but the top is just above freezing, then your problem may be either your defrost timer or the defrost heating element. You'll need a thermometer to determine how cold (or not cold) your freezer is getting. Usually a freezer is happiest when it's full, so being too full is likely NOT the problem (there is room for air to circulate, right?).
If you're handy, you can troubleshoot the problem yourself by following the suggestions found here, as that may at least identify the problem. Replacing components inside your refrigerator isn't incredibly complicated, but if you're uncomfortable with taking things apart, you may be better off seeking the help of a properly trained professional.
Hope this information helps!
Posted on Aug 26, 2009
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
Only top section of chest freezer is freezing
Hi
Normally what causes the refrigerator/lower chest not to be cold enough is that the fan that pulls the air from the freezer is not working.
Check to make sure it is working, if not then you will have to replace it.
If it is working then check you defrost timer, it could be faulty.
I will include these two websites for parts.
partselect.com/
appliancepartspros.com/index.aspx
Please take time to rate me
Bud
Mar 15, 2013 | Freezers
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Apr 12, 2011 | Freezers
Freezer stopped freezing. food started getting soft on top. power light on. green light off. tapped it , green light on. less than 1 yr old.
Good luck.
Mar 02, 2011 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
This is an upright Kenmore freezer. It keeps cold for a few months and then loses its coldness. Turning up the thermostat has no effect. This has become very frustrating since we have to throw out the...
I suspect, you have low refrigerant in freezer. You may have a leaking pipes. Please get fix the leaks first the top up your refrigerant to normal level.
Sep 02, 2010 | Freezers
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
286 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
