Question about Vizio Televison & Video
My vizio e600i-b3 wont turn on. I have 12.#vdc on the output of my power supply. I replaced the main board but didnt fix it. Could it be the tcon board?
Posted by Erick Scott on
1 Related Answer
richie46
  • 12962 Answers
SOURCE: I have replaced the power board, the main board, the t con board and all the cables on my Visio e600i-b3 tv and all I can get is audio and vertical lines
Could the screen itself be defective since you have replaced just about every conceivable part? Does set have a video output that you can monitor? If so, and it works, then the screen is definitely the offender.
Posted on Apr 10, 2017
1helpful
Vizio P602ui-B3 won't power up. during viewing 1/2 of screen went awsy then other half froze. shut down wont come back on. Power light comes on - then fades. Then power light flashes 16 times. is that...
More than likely that is a main board problem. Check to see if you have stand by voltage. if you have stand by its the main board if you don't then its the power supply.if you change the main board out and it don't work then your Tcon board is bad too. thats the problem 99%
of the time when you have half screen.
Vizio p702ui-b3 power board t-con voltage reading do not match what printed on power board
According to the service manual on your set you should see 12 volts on the power fuse on the tcon board...what do you have
I have a vizio E600I-B3. The screen has this green bar and sometimes it turns kinda purple.
There is a chance its the Tcon but it could be the main or cables and connectors as well...or the ***** sentence of a bad panel...one nice thing about timing boards they aren't usually very expensive
Why my TV will not turn on?
Check the fuse first. Then verify if the different supply voltages are present using a voltmeter. Your board can be repaired or replaced from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
1helpful
My Vizio E600I-B3 TV is turning off. It did this for a couple of months and it would sometimes take a minute before we could turn it back on. Is this a power supply board problem?
it is a capacitor issue, when you charge or turn the tv on the capacitor has to charge, the capacitor storage of power, than it discharges to the circuit design for, one or more capacitors maybe bad or defective, there mite be a crack in the capacitor. take the tv into a dark room than turn it on to find what capacitor is bad, and what part of the module. look for burn areas on the capacitors and any type of ground or frame of the tv.
2answers
How to repair display on vizio e600I-b3
it needs to be taken to a repair shop; problem can not be fixed by you.
5answers
Vizio P42HDTV Power on Diagnosis
Relays are the first big clue, triggered by the 5 & 12v supply you should be able to trace back using a dmm and see if you have both of those voltages present... The lead coming from the smps to the y-sus board is a good start. On a Vizio I believe the voltages are listed per pin right on the board...
If you had any kind of relay sound then you could suspect the y-sustain or z-sustain board or something else. With the relays being silent I'd strongly suspect the power supply.
Bill
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
