Question about Furniture
My Garrison water cooler is not cooling the water, but the compressor keeps running and the green light is on indicating that it is cooling?
Posted by Joanne Smith on
5 Related Answers
Anonymous
  • 149 Answers
SOURCE: Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Posted on Apr 24, 2008
douglas smith
  • 1462 Answers
SOURCE: Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Posted on Oct 02, 2008
Anonymous
SOURCE: My Greenway water cooler/heater does not cool the
I have exactly the same problem. Greenway here in Canada don't want to know. Its over a year old so Greenway wont cover it under their warranty. Being 'Fit for Purpose' doesn't come into it.
Posted on Jun 11, 2010
Anonymous
SOURCE: Is there any fix for a Sunbeam Brita water
Apprently this unit is unrepairable. I rang Sunbeam and it has a two year warrenty. I suggest you give them a call too as they were very help full to me.
Posted on Aug 02, 2010
Yogesh Kshatriya
  • 1040 Answers
SOURCE: Cooler won't cool. Fan is
hi,
not just the compressor running is fine but the compressor should have gas in it... if the compressor gas has been wiped out in the same case also the refrigeration will stop cooling....
Hope this has helped you... thanks
Posted on Aug 18, 2010
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
Why does my garrison air conditioner (5200btu) not dehumidify and cool at the same time?
people are giving you answers for a "broken" unit. I have the same Garrison 5200BYU, and it's something I hate about it. You'll notice on the controls, theres a setting for "cool" and one for "Dry". Can't run both at the same time. I've never had an air conditioner that didn't dehumidify the air. After all, for cripes sake, it's why they're not called "aid coolers", they're called "air conditioners"! But I don't think your unit is broken, it's just a strange thing with this Garrison. I don't know if all Garrison are like that, or just this one. But this model is for sure. I wouldn't buy another.
Aug 06, 2013 | Danby Heating & Cooling
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
I have a ATLAS COPCO GA 160 w at my work and it is shutting down on high element temprature. I noticed that the oil level in the seperator is low and have topped it up a few times but everytime i run it...
Without more info or knowing your compressor my first question to you is,is the oil cooler clean and does the unit have good water flow. DO you have good water flow / pressure. The oil level should be about half way the sight glass running loaded. If the oil level was low ,when the thermostat opens it allows oil to flow to the cooler which lowers the oil level.Typical problems during this time of year are , , dirty oil cooler, Faulty thermostat, Faulty element temperature sensor, Low oil levels and bad oil. Also dirty oil filters restrict oil flow and can cause high element temp. problems. Try back flushing the water side of the oil cooler. Have you checked to make sure the water solenoid is opening. May have a bad coil or valve. May also have water solenoid plugged with something. What is the cooling water inlet temp and outlet temp. The W usually indicates water cooled. If not water cooled, most of the above also applies to air cooled units. just replace water with air if it fits.
Jun 28, 2011 | Air Tools & Compressors
Have a Haier water cooler with the fridge compartment in the bottom. Compressor on the unit just started running continuously, instead of cycling on and off. now the chilling bowl that cools the water...
removed one of the two thermostats... the one that controls the temp in the lower refrigerated compartment. Now the water cooler functions correctly but the lower refrigerator is not cold enough to keep perishable food in it, but its better than it was.
Dec 09, 2008 | Haier Refrigerators
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Furniture Logo
281 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
