Question about Kenmore Refrigerators
Kenmore refrig cu ft model253.64802400 I need to know
Posted by Sue Montgomery on
5 Related Answers
tzweeb
Tom Zwiebel
  • 318 Answers
SOURCE: trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Posted on Jan 31, 2009
SOURCE: What is the capacity (cu ft) of Kenmore washer
3.2 cubic feet
Posted on May 12, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Kenmore 26 cu ft side by side refrigerator 51673100
I think the Adaptive Defrost Control may be your problem part number 12566102 You may find it inside the fresh food compartment and behind the controls where you adjust the tempertaures. I will return with photos and links, Sea Breeze
Posted on Dec 20, 2009
Testimonial: "Great Help Thanks!"
Anonymous
  • 712 Answers
SOURCE: I need to know the interior cu. ft
You can just measure it simply using a tape. The ones provided by the company differ from the actual volume.
Posted on Apr 21, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Where is the manual depfoster switch for the kenmore elite refrig with bottom freezer??
All defrost activity is managed by the unit's main control board. I don't believe there is a manual defrost switch.
Oct 08, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Need wiring diagram for kenmore elite refrig- 596.765295001515031
http://appliancedigest.com/index.php?/files/file/498-16025629-maytag-amana-bottom-mount-refrigerator-service-manual/
Nov 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Both freezer and refrigerator are warm and fan is running and compressor is hot
check model number. if the first 3 numbers are 106. this is a whrilpool made refrig. they have a lot of start kits going bad, It consist of a relay, overload and a relay. you need to replace all three. you can purchase a 3 in1 start kit that will work on all the home refrigs. Check local refrig parts house. usally the small hp kit is fine.
Mar 05, 2010 | Kenmore 26.0 cu. ft. Side-By-Side...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrigerator will not shut down,,0 deg. freezer 39 refrig
Replace the defrost heater and thermostat in the freezer compartment.
May 23, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Just purchased used 596.73824200 bottom freezer. Would like to know year manufactured and size in cu.ft.. Need lower shelf for freezer door. (Do not have a manual)
you can go here and find the parts you need. i really cant tell what age your refrig is by the model#  i believe it is a 24 cu ft. if you can give me a serial# off of the unit i can tell yo how old the unit is. thanks Peyton
Feb 18, 2009 | Kenmore 73822 / 73824 Bottom Freezer...
Need to clean out the defrost drain tube on our Kenmore refrige
remove the back freezer panel and the drain is below the coils in the drain trougth. use hot water to remove the ice to get to the drain inlet.
Dec 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
83 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
