Question about Olympus Science & Laboratory
Purchased olympus plus so I could burn cd and dvd
Purchased olympus master plus so I could burn cd and dvd and it tells me that neither drive excists please help
Anonymous
Not solved it. I would like an answer to it and you do not seem to be able to help me without me having to purchase something else.
Posted on Aug 26, 2009
My cd/dvd drive will not burn cd's or read dvd's
may be its problem with your dvd writter better you replace new one
2helpful
Refurbished Dell Optiplex GX280 with DVD/CD-RW Drive will not recognize blank CDs in order to burn music. I was told by the seller that I had to purchase burn software. (I also had to purchase CinePlayer...
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
My Ge Force will burn audio but not DVD.I have tried with Ashampoo,Record Now and Express Burner.The burning programme tells me there is no disc in drive
Hi Brian.
I think you are a little confused.
Your GeForce FX 5500 is a graphics card
All this does is allow you to see your desktop on a monitor and play some games.
For burning discs you need a cd/dvd burner. This is a cd/dvd drive that you can use to read and write cd's and dvd's
You say that your program is telling you that there is no disc in the drive. (Your CD/DVD burner drive)
You can burn audio discs so this tells me you know that much and you have blank cd's so my two things I need to tell you are these..
1. To make a DVD or Burn a DVD you need a BLANK DVD disc in your burning drive. Maybe you have mistakenly placed a CD in the drive instead?
2. Your Burner drive may not burn DVD's only CD's?
Check on the door to the drive that opens to allow you to place discs into it. It should say something like DVD multi recorder or Compact Disc re-writeable. If it does not say DVD on it anywhere your drive is not capable of burning DVD movies and therefore you will need to purchase another burner.
I hope this helps?
1helpful
Can you connect a cd/dvd writer to a toshiba tv
I don't think you can because you would still need to have a program to tell the burner what to burn. You can purchase a DVD burner with HDD on it, kind of like a stand alone TiVO plus dvd burner, but I don't think you can burn from a TV like that.
Good Luck,
NOLA Tech
The disc drive wont burn a dvd or even play cd or
was it preinstalled or you installed it yourself ? either way sorry to tell you but drives do give out, and some times the cd-rom and dvd - rom drives the hardest to fix, but you can research http://www.geeks.com/ and find yourself a new one for around 40-50 dollars...
another thing, if you installed this drive yourself, you can pull it out and check the jumper and make sure its either cable select or slave or master, which ever you want to set it up as....
i usally put all my drives in cable select so the computer will select which drives goes first and things are juts alot easier that way....
Problems burning a DVD from my Dell Dimesion 3100C
check the jumper on the back of your DVD/CD drive. Try to select it as master then cycle power on your PC and see what happen
1helpful
Transferring images from Olympus Master Folder
must be transferred to a computer folder then the cd
2helpful
3answers
Acer Drive d icon in my computer
DMagnus and Guest
when your pc is starting, click on DEL to see BiosSetup. In BOOT SEQUENCE, where you can find FLOPPY, MASTER 1, SLAVE 1, MASTER 2 and SLAVE 2, see in SLAVE 1 if your D DRIVE NAME appears or try to select it clicking in ENTER and changing in a hardware list that will show up. If you don't see your D drive's name there, means that it's not working anymore and needs a new one like that.
Normaly, Acer comes with Philips DVD's (about CD players I don't know) and has as variation only the model (example: Philips DVD-R+RW S8441) , wich is the mark that you need to know and search in BIOS SETUP.
hope this helps to you know what happened ;-)
2helpful
You have to buy the upgrade to Olympus Master 2, to be able to burn images to a disc.  Olympus Master doesn't allow you to.  I get around it by manually saving my images in an additional folder on my computer and then burn them to disc from there.  It's a slow process and very inconvient.  Good luck.
Science & Laboratory Logo
Top Olympus Science & Laboratory Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you an Olympus Science and Laboratory Expert? Answer questions, earn points and help others
