Expert
- Posted on Aug 30, 2009
Re: Kenmore Washer Model#23922200 does not spin clothes...
I assume this is an older top loader. You may have something stuck in the pump itself. I can tell you how to check this. Following is cabinet removal instructions:
- Using a Phillips screwdriver, remove the screw from each side of the console.
- Pull the console forward and up to remove the tabs on the bottom of the end caps, out of the holes in the top.
- Lift the console up and lay it on its back.
- Unplug the harness connectorfor the lid switch.
- Insert a flat screwdriver into the front edge of the clip (located on both sides), and pry back. Remove both clips from the holes in the cabinet and slide down the other end of the clips and out the slot in the rear panel.
- Open and hold the lid while grabbing the cabinet front opening. Be sure when tilting the cabinet that the back edge clears the vacuum break.
- Tilt the top of the cabinet toward you by pulling on the lid and opening of the cabinet. This releases the back slots of the cabinet from the tabs in the back of the base.
- Carefully pull the cabinet away from the base of the washer and set it aside.
Now you have access to most of the parts.
Now in front of you on bottom is the pump. It's usually white in color. Without taking it off the motor, make sure it is someplace where you can let the water run out of the machine. Remove the clamp from the wash tub to the pump and look inside. There may be a small garment or something similar inside. You can use a small needle nose plier to get to this and remove it. Reattach the hose and close the cabinet in reverse order.
Hope this helps you
Joe
i think the model number you put down is the serial number? I cannot locate a model number like this one anywhere :( Should be on a plate just inside the lid of the machine.
