To remove the micro SD card push the micro SD card in further, it will click and then pop out. To insert the new micro SD card insert it into the phone and push it in until it clicks in.
sharp, you have to format the SD through your phone and then copy the music to the folder provided by the phone for the music. make sure you check the playing / bitrate / file type of audio file that the phone is limited to play.
Only the Sprint version of this phone supports memory cards over 1 Gigabyte. Sorry. But if you have a Sprint phone comment back to me using the comment box below. Thanks.
If you don't have a Sprint phone you need to acquire a 1GB card and use that. Hold on to your 2GB card as it will be usable when you upgrade at the end of your contract period.
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
soda monster, first of all wuz up man? the answer is yes, i had a razor v3i pretty much same thing to urs, and i installed a 2gb micro sd and it worked, and later i replaced it with a 4 gb card and it worked too. but sometimes when u have to many songs and pictures the phone will become slow and at times freezes ur phone too much, u will have to remove the battery and turn it back on, thats the only bad part , so a 2gb micro sd is recommended.
