Question about Sony Playstation 3 (PS3) Console
Can't get video or sound!
I tried turning the playstation off and then hold the on button for 5 seconds and nothing worked. What should I do next? Is there a problem with my PS3??? I tried different outputs on my reciever and on my TV.
Posted by johnnyf45 on
Anonymous
    Scholar:
  • 72 Answers
Put a game in put it on standby hook your controller with the usb lead in (red light) press and hold power it will beep ,beep , double beep shutdown by itsself turn it back on it should default back rf
if not do the first instructions again but power back on by holding down again beep, beep, double beep but let go of the button b 4 it shuts down and there will be a dev mode this is something sony dont want you to know if helps give me a tick so to help others
Posted on Aug 25, 2009
The PS3 system reads discs with music and video but does not read discs with games on for PS3
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Restore File System
Rebuild Data Base
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
PS3 Won't load games
Welcome to Fixya
Restore File System
Rebuild Data Base
Cheers!
Dec 30, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not read discs
Welcome to Fixya
Restore File System
Rebuild Data Base
All the best!
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Dvd works games don't ps3
Welcome to Fixya
Restore File System
Rebuild Data Base
Thank you!
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
PS3 not recnising discs
Welcome to Fixya
Restore File System
Rebuild Data Base
All the best
Dec 07, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wontplay games
Welcome to Fixya
Restore File System
Rebuild Data Base
Cheers
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
When I turn on the PS3 it does not boot up.
Hi try to restore/rebuild your database and filesystem.
in worst case do the "Restore PS3 System" this gonna wipe your harddrive, so remember to backup your saves, games that you bough on PSN can be redownloaded fromt he store.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 10, 2009 | Sony Playstation 3 (PS3) Console
All the connections work the ps3 comes on but then goes black
You may have messed up the Screen-Settings, to solve this try this.
Step 2:
Step 3:
Step 4
  3. Rebuild Database
  4. Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    Step 3:
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    3. Rebuild Database
    Oct 04, 2009 | Sony Video Game Consoles & Games
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Lee Hodgson
    Lee Hodgson
    Marvin
    Marvin
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
