Re: how do you delete groups of pictures from an xd card
If you have safely downloaded them to your computer, you can format the card in the camera which will completely erase it and prepare it properly to work in the camera.
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130) To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
(p.130).
If the message still appears, replace the xD-Picture Card
Many older camera do not support larger memory cards. Your camera limit is 512 meg card. I would guess the new one is 2-4 gigs. If it is a 4 gig card, it won't work. If it is a 2 gig card it will work with a firmware upgrade from Fuji. here is the site; http://www.fujifilm.com/support/digital_cameras/compatibility/card/a/
Please rate this answer by check on the "hands" below. j
If you deleted the pics whilst the camera was connected to the computer, you can get them back by reconnecting the camera with the XD card in it, then going to the recycle bin, and right click on it then click on each pic and then on restore, if you deleted them through the camera itself then the pics were physically removed from the XD card, at which point your not using that particular XD card will keep the card in the state it was in (as if you use it it may overwrite in the slots that those old pics were in and make it difficult if not impossible for the data recovery expert to retrieve) when you deleted them and the only way that you might be able to get them back is by enlisting the services of a data recovery expert, however their services are very costly so you have to shop around.
I did some checking and found that another expert had a similar question on 10/2/08. According to kenshin99, the limit on the cards is 256mb but some have had luck with the 512mb cards.
I think your best place to find those would be on sites like eBay or Craigslist
Check the maximum capacity memory card that your older camera will take. My Fuji will only take up to a 2gig card unless I flash the firmware in the camera to take the newer 4gig cards. Some of the older cameras maxed out at 1 gig or less. Check eBay for smaller capacity cards as they are getting hard to find in stores.
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
I've have xD cards that I thought I deleted the photos, but they showed up on the Xd card when i put it in the card reader to download another set of pics. I think it happened because I used the card in 2 different cameras (thus, the cam each saved pics in their own different formats).
I've solved it. I'll bet a buck you also bought a memory card reader. If you hook the memory card (or camera) to a computer, you'll see a directory with a name like fuji_999. After you download the pictures delete that directory from the memory card, and the problem's solved. I just did it with a 1 gig xd card in my daughter's fuji 480. It had a main directory on the card called DXsomething, and 2 subdirectories, fuji_100, and fuji_999. I deleted all three directories (after saving the photos), and the problem is gone. Hope it works for you.
What is the advantage of a 1 gig over two 512meg cards:
Usually the 1 gig will be priced lower than 2 512 cards.
The 1 gig card will hold twice as many photos.
That is about it.
Brand name has turned out to be a non-issue for almost all memory cards. They have to be made to a standard and they will all work.
Olympus and Fujifilm came up with the xD card.
And Sandisk is a trusted card maker.
I believe that Olympus may have a stitch feature that is only available if you use the Olympus brand of card.
A gimmick to sell more of their brand of cards.
This is pretty much of a non issue too, as there are plenty of software programs that can do stitching for panorama photos.
