SOURCE: can't raise the saw assembly in ordr to cut wood
Search the rear of the saw for a locking latch or pin...
SOURCE: handle to raise and lower blade is stuck in the down position
What I do is use some penetrating oil on the mechanism that raises and lowers the saw unit. Usually you will have to raise if a little and then lower and keep doing over until it moves freely. If the unit is rusted you might have to wire brush a little. I dont know what brand or model we are talking about but this works on the DeWalt and Bosch saws that I repair.
SOURCE: bevel locking lever won't tighten
It looks like that handle should be able to pull straight off the end of the shaft once you remove the screw. See this exploded parts view: http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_2703.pdf
My experience with them is that people tend to get frustrated and abandon the lock lever and just run the saw "loose". Scary as it sounds, I've seen it on more than one site.
Anyway, I don't have a fix for you if you can't get the handle off to re-position it.
Makita does have a tech support line if you want to give it a try. Otherwise, you may have to shell out a few bucks to one of their service centers. We used to have a great one in Albuquerque, but it's now defunct. People don't seem to repair tools like they used to...
Locate Nearest Service Center online
or Free technical support center (1-800-4MAKITA)
Monday – Friday 7:00am – 7:00pm EST
Good luck, and best wishes...
SOURCE: It's extremely hard to turn the handle to raise
Bosch has a technical bulletin to address this problem, it requires the adding of shim washers under the gear and above the hex nut. If you are still having a problem let me know and I will get part numbers for you.
SOURCE: My KING KC-115C Horizontal metal cutting band saw cuts off track.
I used to work for Doall saw company. While I am not familiar with the particular model you have, I have seen issues like it in Doall saws.
Firstly, If bearing guides are not adjustable, replace them. There should be only about a 32 of an inch play between them (in addition to the thickness of the blade). Secondly, for a prodution horizontal bandsaw you should have the blade tensioned a @30,000 psi. Thirdly, if after that, you are still having problems, I would suggest checking the bearings on your drive and idler wheels for runout (in addition to the condition of the tires).
