Question about Lands Phones
I need to know how to use the caller id on the NEC Aspirephone Model IP1NA-12TXH Tel (BK)
Posted by MetroSubRLC on
Anonymous
    New Friend:
Why is the Metro Suburban Recovery Learning Community such a messed up organization?
Posted on Apr 25, 2010
Anonymous
I need to know how tosee my call and delete then fron the phone
Posted on Aug 24, 2009
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Oct 02, 2014 | NEC Lands Phones
Nec 12txd phone not ringing and led indicator not working.
the only other setting that could turn the led off is if you enable blocking mode and you check disable led indicator (found by long pressing blocking mode in the pull down window). do you have any apps that could control the led lights like light manager? if so, try uninstalling it or checking its settings. if you dont have an apps like that, have you tried installing one to see if it works?
Feb 24, 2014 | NEC Aspire 22 Button Ip1na-12txh 0890043...
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
RECALLING PHONE NUMBERS
while talking on that line press line key again.
Feb 23, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Nec 22b hf/disp aspirephone-bk
1. have the first call on the line (do NOT put on hold), (call 1 or 2)
2. press CONF key
3. dial 9 for an outside line and dial the number
4. press CONF **twice** to join calls.
Nov 10, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Caller ID Scroll
Your system needs to have a mif-m card and kmm chip installed and all programming setup in order to scroll through the caller id. If this is all setup you can hit the directory button and than use the arrow buttons under the display to scroll. ldtsnj.com
Oct 30, 2008 | NEC DTU 8D-2 Corded Phone
Lands Phones Logo
305 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
