Reset the Walkman by pressing and holding the Reset button for 30 seconds. Then, try transferring or deleting any files from it. Furthermore, if the issue persists then try formatting the internal flash memory.
Follow the steps given below to format the internal flash memory of the Walkman:
Press and hold the Back/Home button in the Pause mode until the Home menu appears.
Press the up/down/left/right button to select Settings, and then press the >|| button to confirm.
Press the up/down/left/right button to select "Common Settings," and then press the >|| button to confirm.
The list of "Common Settings" options appears.
Press the up/down/left/right button to select "Format" and then press the >|| button to confirm.
"All data including songs will be deleted. Proceed?" message will appear.
Press the up/down button to select "Yes," and then press the >|| button to confirm.
"All data will be deleted. Proceed?" message will appear.
While the memory is being formatted, an animated display appears. When initialization finishes, "Memory formatted." message appears.
