X-135 won't show depth and alarming eratically..unit powers up and off normal...problem got worse in time..at first the unit would find depth but it took some time then it started giving a 3 digit depth reading in say 10 ft. of water..mounted flush in bow of triton (factory unit) 2007.transducer is puck style and has been cleaned..
I assume that when it resets to 2.2 feet that the readout is flashing. If so the it sounds like you have a bad transducer as the problem has been getting progressively worse.
The transducer needs to be replaced. Sounds like the sending crystal is fractured.
DEPTH ALARM An alarm on a divers' watch that sounds when the wearer exceeds a pre-set depth. DEPTH METER or DEPTH SENSOR A device on a divers' watch that determines the wearer's depth by measuring water pressure. It shows the depth either by analog hands and a scale on the watch face or through a digital display. DECK WATCH A large-sized ship's chronometer. DEVIATION A progressive natural change of a watch's rate with respect to objective time. In case of a watch's faster rate, the deviation is defined positive, in the opposite case negative. DIAL Face of a watch, on which time and further functions are displayed by markers, hands, discs or through windows. Normally it is made of a brass - sometimes silver or gold. DIGITAL WATCH Said of watches whose indications are displayed mostly inside an aperture or window on the dial. DIVERS' WATCH A watch that is water resistant to 200M. Has a unidirectional rotating bezel and a screw-on crown and back. Has a metal or rubber strap (not leather). May have a sapphire crystal and possibly, a wet-suit extension.
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed):
- Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
Heater unit faulty
Wiring faulty
NTC sensor incorrectly calibrated/out of position
Electronic board faulty
E62 - Power reley to heater unit faulty
Heater unit faulty
Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
Readings You May See When Unit is AC Powered Display Shows Alarm Sound Unit Status Recommended Action Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer and flashing dot 30 seconds AC powered service at 1-800-880-6788 Readings You May See When Unit is on Temporary Battery Backup Display Shows Alarm Sound Unit Status Recommended Action Flashing dot None Normal battery-only operation - Plug in to AC as soon as unit will show reading only if it possible to conserve battery senses CO Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer "Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here: http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Your printer most probably has the scanner unit dirty. Unfortunately, this is the type of service that requires a great deal of printer disassembly. My advice is a good Samsung Authorized Service Center. Just ask them to show you their certification.
