Sony Ericsson K850i  Mobile Phone Logo
Posted on Aug 24, 2009
Sony Ericsson won't switch on Battery is charged
Sony Ericsson K850i won't switch on Battery is charged
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
155
Points
Repaire power ic or power supply
How to unlock se k850i
To Unlock Sony Ericsson K850 use unlock code.Visit the site
Superunlockcodes.com
get Unlock code and Follow the unlocking instructions below and unlock it easily.
Sony Ericsson K850i Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson K850i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson K850i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson K850i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
Nov 24, 2012 • Cell Phones
1helpful
Sony Ericsson K850i not switching on
Try reading K850i Firmware Overview.. There are some issues with firmware. Such as random reboots and BROD (Blue Ring of Death) i was recently victimized by this BROD. 037 firmware is the most stable firmware so far.. i would advise you also to downgrade your firmware first until SE releases a new and more stable firmware..
1helpful
K850i charging problems and red light flashing at on/off key
Your battery is either not charged or the battery cell is completely gone.
I'll advice that you get another battery and give it a trial, also look out for the charging port. Check if it is not rust in any way because, if the charging port is rust, it will be difficult for the charger to contact the charging port.
I believe what's wrong with your phone is a minor fault, just do a thorough check and you will find a solution to the problem.
Best wishes.
Keeps coming up with Maxmized charging but won,t
You need a new battery, The battery has been used up too many times.
1helpful
My mobile will not turn on or charge
two cases
1. Battery is uncharged. Charge your battery.
or
if above does'nt helpthen i think there is problem with your battery.
Unlock K850i
There are no free tools available to unlock the phone.
You can use this website they would charge you lesser than your service provider.
http://www.uniquephones.com/Sony-Ericsson-K850i-Unlocking.html
Spilt juice on my sony ericsson
u r charging ic has been damaged u need to replace the board or check the battery output pins it must be 3.6volts
My sony ericsson k850i keeps switching itself off and doesn't charge properly.
the problem is wit the battery... change ur battery... everythin wil be rite
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
