Question about HP DeskJet 940c InkJet Printer
Software not finding printer. Printer is showing on taskbar and in control panel.
Posted by o12no1 on
Josh Pongco
  • 154 Answers
Make sure that the USB cable is properly connected on your printer and the port from your pc as well.
Check the Device Manager, and see if your printer is under USB Controllers, if not try using anothe USB cable.
Thanks
Posted on Aug 24, 2009
Hp 2600 no longer prints from my laptop
Hi Friend,
I think One time uninstall printer software and restart laptop and installation before clean the virus in laptop then install printer driver. If any error show in installations time then antivirus sort time disable. And software full install then proper check it printer driver show in control panel. If problem same then change printer cable connector.
If then not solved then finally you check other OS laptop may be find error.
Thanks..
Jan 14, 2014 | HP Photosmart 2610 All-In-One InkJet...
Tip
How to uninstall and reinstall HP Deskjet D2360 Printer
Hi,<br /><br />I think you need to uninstall and reinstall your HP printer drivers.<br /><br />to do this follow these steps:<br /><br /> 1.<br /> Select Start , Settings , and Control Panel .<br /> 2.<br /> Double-click the Add/Remove Programs utility.<br /> 3.<br /> Select the HP Deskjet D2360 Printer and click Add/Remove<br /> 4. Restart your computer<br /><br />To reinstall HP Deskjet D2360 Printer<br /><br /> *<br /> Make sure that the printer is properly set up, turned on, and ready to print.<br /> *<br /> Check that all cables are firmly connected.<br /><br />For Windows XP<br /><br /> NOTE: You must have administrator privileges in Windows XP Professional to install a printer driver.<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />For Windows XP Home Version<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Control Panel , Printers and Other Hardware , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response<br /><br />Thanks,<br /><br />LETMEFIXIT
on Feb 02, 2011 | HP Deskjet D2360 InkJet Printer
How do I connect for printing my Toshiba Satellite Laptop computer to my HP Deskjet D4260 printer? I have the wire conected properly from the computer to the printer, but need to know where on the TASK...
make sure to install the driver for the printer here is the link u have to select ur operating system and after u install the software and driver ur printer should just work...u can locate the printer icon in the lower right hand corner of ur taskbar where the clock is... r u can go to the control panel and select devices and printer and there u will also see ur printer.
Jul 01, 2011 | Toshiba Computers & Internet
How do I get a report showing total pages printed by this printer during its life?
Hi there! SMILE & KEEP COOL !
Follow these steps to find the page count number in the print driver.
  1. Depending on your operating system, follow one of these steps:
    • Windows XP : Click Start , and then click Printers and Faxes .
    • Windows Vista : On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Printers .
    • Windows 7 : On the Windows taskbar, click Start (c01319360.gif ), and then click Devices and Printers .
  2. Right-click the icon for your product, and then select Properties from the drop-down menu.
  3. Click the General tab, and then click Printing Preferences .
  4. Click the Basics tab, and then click About .
  5. Locate the page count at the bottom of the About This Driver screen. Figure 1: Page Count number location c02019814.jpg 1 - Page count Illustration: Location of the Page Count number in the About screen of the print driver.
PLEASE SEND US YOUR VOTE & FEEDBACK! THANKS !!!
Mar 05, 2010 | HP LaserJet 5mp Printer
My printer will not connect to my laptop
You need to put your printer back online. Depending on your operating system, (I will assume some flavor of Windows) you need to find your printer listed in "Control Panel". Right click your printer icon with your mouse, and choose "Use printer online".
If the document does not print and the job remains queued, a printer icon will appear to the left of the time on the Windows taskbar. Double-click the printer icon in the taskbar. Click on the document title. From the document menu, click "restart".
Dec 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Change ink caryridge
Install the EPSON driver software on the PC, connect the printer and the EPSON status monitor (Little printer icon on the taskbar) will show you howto replace the cartridges on your model.
Oct 28, 2009 | Epson Office Equipment & Supplies
Prints look washed out .Plus cartridges show empty even though they have just been filled. Noel
If using generic cartridges, try using original manufacturer's.
If utility software installed, try running the head/nozzle/check/cleaning/realigning functions.
(look for an icon in taskbar or in directories installed by your printer software)
Jul 03, 2009 | Canon PIXMA MP470 All-in-One Printer
I have got a problem with my printer hp photosmartc4180 series it wont let me print i try different situations now i have contacted hp they say it needs cleaning by compaq
What happens when you try to print?
1. When you try to print do you see the printer icon on the taskbar? (lower right)
2. Do you see the printer in your printers folder?(start/settings/control panel/ printers) Might need installed
3. Is the printer your default printer? (right click on the printer in the above area and select "set as default printer")
4. Is it plugged in, turned on and plugged into your computer?
5. Has the software been installed or recently updated?
Let me know if this helps
Dec 31, 2008 | Computers & Internet
Can't find my software for printer utility to clean my printer
Go to START.....SETTINGS........PRINTER AND FAXES......rite click the printer you want to work with select properties...
keep me posted if this didn't work...
Cheers!
Nov 13, 2008 | Epson Stylus Photo R1800 InkJet Printer
HP DeskJet 940c InkJet Printer Logo
37 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
