Question about Refrigerators
Water being generated; pools in bottom of cabinet and drips out from there.
Posted by Jim Williams on
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 32,301 Answers
There are only a few scenarios where the water is coming from to congregate there.
Condensation from putting food in there which is warm, especially anything not wrapped or bagged.
Defrost water drain blocked. Look for a channel at the back or within the blower unit. (this is the most likely)
Badly fitting, split or worn out door seal. This lets warm moist air from the room into the cabinet which then freezes.
Excessive frost build up reducing efficient circulation of air, or overloading.
Finally, kids spilling water!
Posted on Jul 08, 2019
5 Related Answers
Anonymous
SOURCE: WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
Anonymous
  • 21 Answers
SOURCE: ice build up
There may be a drain tube for the frost free located in the panel behind bottom drawer. The drain tube sounds to be full of ice. You will need to remove all items from freezer and use a hair dryer to melt the ice fully. Also remove the cover panels so you can tell when you get the drain unplugged. Pour hot water down to make sure the line is melted and free of other pluggage.
Posted on Nov 13, 2008
Anonymous
  • 29 Answers
SOURCE: Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Posted on Jan 29, 2009
Anonymous
  • 1122 Answers
SOURCE: Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Posted on Mar 16, 2009
SOURCE: I have a Tefal Pro express iron and I have water
There is a seal or a connection leaking. Take the iron apart -- you'll probably see where it's been leaking.
Posted on May 04, 2009
How do i stop steam vapors from coming out with heater exhaust
make sure the drain pan on bottom isnt plugged or hose make sure to change out rocks and fill pan with water
Nov 03, 2012 | Jandy Laars Hi - E2 350,000 Btu Heater
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Kenmore elite (795.75544401)is suddenly dripping water from the bottom of left french door.
The dripping water could be from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 18, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
Water fills up in bottom
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.Check for both possibilities. The solution to the trouble lies in one of them.
Best of Luck,
Concerned.
Aug 18, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Unit is leaking internally, then water drips out of bottom
check for cracks in the housing, or it could be cross threaded, This is very comon.
The Pool Tech
Jun 01, 2010 | Zodiac Duo Clear System Chlorine...
New whirlpool dishwasher when in use drips from right side.
Check if the dishwasher is level side to side and front to back. (you can generally tell if the edge of the tub has an even space between it and the cabinet at top and bottom, and the tub is not further in or out on top or bottom in relation to the edge of the cabinet. Also, make sure the door is not hitting the cabinet edge when you close the dishwasher door.
Feb 05, 2010 | Dishwashers
Water dripping in to freezer bottom ten pools on
Sounds like you have a drain that is plugged. When it goes into defrost the water hass no place to run. Thats when you get water like that. I would defrost it completly. Then try to get to the drain and pour hot water slowly to see if it goes all the way down to the pan. If not. Yu may have to have air pressure to go thru the drain.
Aug 30, 2009 | Refrigerators
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
