Question about LG Studioworks 700S 17" CRT Monitor
Monitor LED blinking--no display--How to open the cabinet
Monitor have to opened but i m failure
Posted by dinesh_chavh on
Anonymous
  • 290 Answers
Check the vga cable if it is attached properly to your computer. Make sure that the VGA cable is connected to the Video Card that you are using.
check in the manual if you need to install the driver first.
also check if the monitor will work to another computer. If not, Then you can check the VGA Cable and replace a new one.
Hope this will help you out .. =)
Posted on Aug 24, 2009
Anonymous
    Problem Solver:
  • 10 Answers
Hi
1. First suspect the vga cable use another new one. If your vga is
fix to crt monitor open it use analog multimeter range
x1 or x10 for checking continuity.Test the unit before you
proceed to next step.
2. Unplug the VGA card use eraser to clean this;
clean vga slot use laquer tainer and toothbrush. if nothing happen
3. Direct your vga cable to motherboard make sure you have built-
in video card. if nothing happen again
4. suspect you have a problem to your monitor. open this
troubleshoot the video section.Plugin and show the heater beam
must have lights if not, desolder the crt socket clean it carefully
& trace the line supplied to heater find open resistor if you have
knowledge for voltage testing much better. Voltage test
the heater pins start at flyback pins to heater crt pins. If you
have no voltage found, find the b+, connect black prove to hot
ground of horizontal area check the voltage use analog tester
range 250v DC i think the normal is 100v - 175 v check the
horizontal output transistor for shorted.
Note:
If you replace new horizontal output transistor recheck it
again if the H.O.T shorted again repalce your flyback
transformer.
Gud luck....
Posted on Aug 25, 2009
1 Related Answer
freetek
Steve Allison
  • 5569 Answers
SOURCE: Monitor LED blinking--no display--How to open the cabinet
Most monitors (among the ~2000 I have repaired) have either four screws at the extreme corners accessible from the rear or only two with the other opposing edge snapped in. Some monitors, will have and extra 1 or 2 screws around the area where the connections are made while others may have only snap-in molded tabs that must be released with a flat-blade screwdriver.
Before bothering the monitor, I recommend you substitute another monitor to ensure that the monitor is receiving the signal inputs it needs to function. Loose connectors and failed video sections can also be the cause as well as a 'lost' driver that Windows has corrupted.
I also suggest you leave the monitor unplugged from the AC ine overnight since there are components that can retain hundreds of volts of charge for hours and deliver as really unpleasant shock if you tangle with one of these points. If the high voltage (horizontal) section is still active, it can deliver around 25,000 volts with enough power to punch a hole through your thumb.
A primitive check for the operation of the high voltage is to hold an AM band radio at various points of the housing. If you get squeals, the horizontal section is at work.
Posted on Jul 15, 2009
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Monitor led is blinking green but screen is black. Unplugged and replugged all cables already.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell E173FP 17" LCD Monitor
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
My pc has no picture appeared only a blink at the led o the monitor
CHECK THE CABLE CONNECTION BETWEEN YOUR MONITOR AND THE PC. ALSO OPEN YOUR PC CABINET AND CHECK WHETHER THE RAM IS TIGHTLY FITTED OR NOT.
Apr 09, 2010 | ASUS Computers & Internet
My HP Monitor Model No: L1706 problem
I sure sounds like you have backlight problem, since when the VGA cable is connected the power LED turns GREEN and blinks when VGA cable is disconnected, it means the video signal is getting to the monitor OK, so more likely the problem will be in the monitor, but just to be sure, you should also try this monitor with another PC first.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 01, 2010 | HP L1706 17" LCD Monitor
Samtron Monitor 56V Display Problem
your power supply is probably bad. open the case with it unpugged and look for leaking or crowned capacitors. most electronic repair shops can replace them for you
Jan 10, 2010 | Computers & Internet
My HP Pavillion keyboard lights up but the screen is blank what can i do?
Press num lock key of key board if num lock led is on/off then your cpu gives display to monitor Then make sure monitor cable is connected properly to cpu vga port.
When you power up the cpu press F8 key then enter in "enable vga mode" Then go to start->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
Then check.
But if num lock led is not on/off and left constant then you need to open cpu cabinet.
Refix RAM memory.Pull cmos cell from motherboard for 10 minutes.
Clean dust from all parts.
Reattach processor and it's fan.
Make sure motherboard is not ground with cabinet.
Open motherboard from cabinet and try outside of cabinet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 24, 2009 | HP (D7580-60003) Motherboard
Jul 15, 2009 | LG Studioworks 700S 17" CRT Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
LG 700E monitor's power LED blinking continueously, no display
LG 700E monitor's power LED blinking continueously, no displaySolution.............
Jan 23, 2009 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
788 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
