Washing Machines Logo
Anonymous Posted on Aug 24, 2009
Model MAH4000AWW door leaks. Has hole worn in it.
Model MAH4000AWW door leaks. Has hole worn in it. There are three different doors listed in parts for this replcement. How do we know which one to order?
Anonymous
Level 2:
Sniper:
  • Expert 68 Answers
  • Posted on Aug 24, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
68
Questions
5
Helped
22614
Points
227
After the part numbers listed for the door liner is a series number. the series is the first two numbers in your serial number. that door has a series 10, 50, or 76. if the fist two numbers in your serial number are between 10 and 49, get the door for series 10. if between 50 and 75, get the door for series 50. 76 and up, get the series 76 door. shane
Testimonial: "Thanks for your help. Explained it to a "T". "
Anonymous
Level 3:
  • Master 612 Answers
Anonymous
Master
Level 3:
Answers
612
Questions
Helped
163648
Points
1827
You will need to go back to your madel number. Look you a series or rev number. 10, 42 or 53. It will have one of these numbers there. This will tell you which part your looking for.
Model MAH4000AWW door leaks.  Has hole worn in it. - model-number-tag.jpg Please rate solution if helpful. Thanks
Testimonial: "Thanks for the help. They all three say for that series and all are the same price and appear to look the same so maybe it does not matter. "
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Water leaking from bottom of the door
It sounds like your problem may be a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the inner door and seal and leave small air gaps. You need to periodically clean this area with a damp cloth to ensure you have a clean surface for the tub seal.
The following link explains some of the common causes of dishwasher leaks and what you can do to prevent them:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service. Prices vary between them, so shop and compare. The first three sites I have listed include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
This is a very simple repair that you can perform yourself without the assistance of a repairman, and it usually does not cost much. The average price of a door gasket ranges from $25 to $45 depending on model. If you have questions, or require additional assistance, please post back with your complete MODEL NUMBER (located along the door opening) and let me know. I hope this helps you.
Leaking water from the front of machine at the bottom of the door.
repairclinic.com
1helpful
Door seal has a inch long hole on bottom side allowing water to drip out this occurs during wash cycle
If the door bellow (gray rubber seal) is leaking it must be replaced to prevent further leaking. The bellow can become mishapened from constant contact with the door over time and not seal properly, or develop rips and tears due to age and overloading.
The following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
A replacement bellow (if required) can be purchased at any of the following web sites:
repairclinic.com
Prices differ between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
The part number for a replacement bellow for the model you have listed is 8182119.
NOTE: The manufacturer recommends that you leave the door OPEN between washes to, not only allow the bellow to keep from becoming permanently stretched, but also to allow the wash tub to breath to prevent mold and mildew from forming.
If you have any questions, please post back and let me know. I hope this helps you.
Leaking from the front door
If the washer is leaking from the door, more than likely the door bellow (gray rubber seal) is causing the problem. The bellow can become mishapened from constant contact with the door over time and not seal properly. There is no adjustment on the door, so when the bellow becomes worn, it must be replaced.
repairclinic.com
1helpful
INSIDE WASHER RING BUSTED WATER LEAKING
If you are referring to the rubber door bellow (gray rubber seal), the following link explains how to access and replace one:
A replacement bellow can be purchased at any of the following web sites:
repairclinic.com
If you are referring to the TUB SEAL that goes around the exterior perimeter of the wash tub where the front and rear halves meet, this is an inexpensive part, but requires extensive disassembly to get to. You can save a LOT in trying to attempt this repair on your own as this can take 1 to 2 hours for a qualified technician to perform. If you have a leaking tub seal and wish to attempt it on your own, please post back and clarify WHERE your leak is coming from.
Refer to the following parts illustrations:
http://pcappliancerepair.com/model-display.php
The door bellow is listed as item 5 under the "Door and Latch Parts" section (part #8182119).
The tub seal is listed as item 10 under the "Tub and Basket Parts" section (part #8181673).
1helpful
Water leaks out of bottom of door
The symptoms you describe, sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
If the model number is correct, the part number for a replacement gasket is 99002588.
Replacement part (if required) can be purchased at any of the following websites:
repairclinic.com
This is a very simple repair. If you have questions, or require additional assistance, please post back and let me know. hope this helps you.
WASHER IS LEAKING FROM THE BOTTOM MIDDLE OF THE DOOR. IS THIS THE GRAY GASKET OR A PROBLEM WITH THE DOOR ITSELF?
If your front loader is leaking, the following link explains how to access and insprect the interior to accurately determine the cause:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
If discover that you need to replace the door bellow (gray rubber seal), the following link explains how:
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If the model number you have this question listed under is correct, the part number you need is 8182119. The bellow is listed as item 5 under the "Door and Latch Parts" section.
NOTE: Although the bellow DOES wear out with age and can develop holes, overloading the washer can contribute to the premature wear and tear on these seals. Please follow your owner's manual recommended loading procedures.
If you have any questions about this repair, or need additional assistance, please post and let me know. I hope this helps you.
Door drops down 1/8' when open. To close need to
If the model number you have this listed under is correct, there is no adjustment. More than likely the door pivot and/or hinges are worn. They can easily be replaced, however. The part numbers are as follows:
Door Pivot - 8184922
Upper Door Hinge - W10114255
Lower Door Hinge - W10114254
You can find these parts at appliancepartspros.com. Just type in the model number and locate items 6, 8, and 13 under the "Door Parts" heading.
If you have questions about this repair, or have a different model number, please post back and let me know so that I may be able to provide better assistance. I hope this helps you.
Top Washing Machines Experts
john h
