Question about Toys
Have fault 03781-01 on man tga 2066 need trouble shooting steps
Posted by bunny mellem on
2 Related Answers
Anonymous
  • 741 Answers
SOURCE: step by step routine when trouble shooting no connection to the internet using a router
Assuming your router is setup correctly and you are currently or have in the past used it and nothing has changed, then there are only two things you need to check. If those things are good, then its not your computer or router its your ISP.
1)Click start>run>cmd to command prompt at c:> type ping 127.0.0.1
That is called a loopback address to your network card. If you receive packets on your screen then your card is ok
2)Click start>run>cmd to command prompt. Type ipconfig /all. This will give you all your IP addresses. They should all start with 192.168.xxx.xxx. Then type ping to your gateway address for example
ping 192.168.0.1. Then sends a message to your router and you should receive packets back. If ok, then your router is good and time to call your ISP. If you have any questions let me know.
Pls rate this solution.
Posted on Apr 15, 2009
linda06
SOURCE: I NEED UNLOCK CODE BECKER
Sorry for my English,
Ik have a problem with my code, because I changed from battery and now my Indianapolis ask for a code, and I dont have is anymore after 5 years.
I have a becker Indianapolis BE 7920 serial nr 45016322.
Can somebody please help me?
Posted on Jun 15, 2011
My man diesel TGA 18.350. it shows me on the dashboard coads 01080_5 and 03076_9 and 03792_5 please i sent my questions but i did not get an answer please i need help
difficulty in find a web page that has the codes properly explained
one site I found ---techtransa.It has a list or the numbers before the under score and what the fault areas are
To get there I went google and typed in--mandiesel model tga-18-350 fault codes--
there are other pages that make reference to fault codes but are not specific to your model
reading around the fault codes are specific to man and it seems that a normal obd-11 scanner will not be accurate
you might have time to down load a good site when you find one , but as I consider a heavy vehicle should be out earning income , time off the road costs money so, in the mean time and until you can find a down load for the faults, maybe you should take it to a service dealer and have it fixed
possible even to get a copy of the codes from the technician
Jan 31, 2016 | Diesel Toys
MAN TGA 26 480 code is 04346-00 what does that meen,please help
In the MAN Fault messages manual there is a EBS fault code 04346-00 that sais: "Trailer control module pressure control: Implausibly high pressure at the end of braking, and parking brake switch and trailer brake switch not actuated".
May 06, 2014 | Bruder MAN TGA Container Service Truck
Edc 3780-10 problems
Hi i have a MAN TGA 07 reg and it has a fault code 3780 coming up which is rail pressure fault what do i have to replace to cure the fault please
regards Damian
Jan 09, 2012 | Bruder MAN TGA Container Service Truck
COD MAN TGA EDC 03050-03
EDC Electronic deisel control
03050 After run test, zero quantity
03 implausible
May 07, 2011 | Bruder MAN TGA Container Service Truck
Does anyone know 5 simple operating faults and how to trouble shoot them of the Dell Inspiron 560?
There is not a easy 5 simple step trouble shooting system for computers.
BUT there is a trouble shooting flow chart for computers.
Go to this WEB site for this trouble shooting flow chart.
http://www.fonerbooks.com/pcrepair.htm
Feb 24, 2011 | Dell Inspiron 560 PC Desktop
How to turn child lock off
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Dec 03, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Toys Logo
147 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
