Question about Bravetti Quad Blade Food Processor
Bravetti Food Processor Model KP80B
Went to use for the 1st time and nothing happen. I unplugged and replugged into evey outlet in my house...IT DOES NOT TURN ON AT ALL.
  • Anonymous Oct 31, 2009
    Rotate the motor by manually...IT WORKS!!!
Ned C Cook
    President:
  • 3,433 Answers
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
Posted on Aug 24, 2009
Testimonial: "YES!!! thank you, I was skeptical but this worked. I insertd the blade holder,spun it around by hand for only about 1 min, then plugged it in.Thanks."
  • Ned C Cook
    Ned C Cook Oct 30, 2009
    Hello; How is the processor doing? Does it fire up on its own everytime now? Just following up. Reminds you of when a person had to hand turn a car motor . Anyway, Hoping all is fine. _Ned_
Neyda Diaz
    New Friend:
I'm looking for the blade holder for my KPOB too. Please let me know if you found it.
Posted on Jan 31, 2015
Mark
    New Friend:
Does any know where I can find a blade holder for this model, (KP80B)?
Posted on Jan 05, 2014
I have the Bravetti Food Processor-Model # KP80B. The unit that uses each individual blade (that is stored in the processor) is cracked and won't work with any of these blades (like for cole slaw, etc.)...
I went to my manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts.
I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
Dec 29, 2009 | Bravetti Quad Blade Food Processor
The motor stopped working i unplugged and replugged into a number of outlets...nothing happens is this a burnt out motor or could it be something simple?
Hi there, I just had the same problem and then found an on-line manual that says this:
An automatic, temperature-
controlled circuit breaker in
the motor ensures complete
protection against motor burnout.
If the processor runs for an
exceptionally long time when
chopping, mixing or kneading
a thick or heavy mixture in
successive batches, the motor
may overheat. If this happens,
the processor will stop. Turn it
off and wait for the motor to cool
off before proceeding. It will
usually cool off within 10 minutes.
In extreme cases, it could take
an hour.
Yayyy! Problem solved (I hope)!
Hope that helps you...
Nov 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I need a manual for my Bravetti Food Processor Model # BP101H Robot de Cusine and parts. Pat
I advise keeping an eye on ebay if you need something in particular. or get a second - used one-just for parts.
Sep 09, 2009 | Bravetti EP109HFS Food Processor
I need a manual for Bravetti food processor model KP80B. Is there one I can download? Received as a gift.
Hi!
You can donwload free Owner's Mnaual for Bravetti Food Processor Model KP80B from the following link--
Owner"s Mnaual for Bravetti Food Processor KP 80B
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 27, 2009 | Bravetti Food Processors
Replace processing glass jar for bravetti quad blade food process
type bravetti in search bar. There might be something you can use in your quest.
Apr 08, 2009 | Bravetti Quad Blade Food Processor
Bravetti Quad Blade 6 Cups Food Processor It is plugged in can't find power switch how does it come on?
unplug it, then use the blade tool to rotate the motor by hand a few times. Not all are tested and turn it by hand will set the brushes. Plug it in and see what happens If you have to turn it several more times make sure to unplug it.. Good Luck, Ned
Feb 03, 2009 | Bravetti Quad Blade Food Processor
I need to replace the Bravetti chopper
Nov 15, 2008 | Bravetti EP109HFS Food Processor
Model kp80b
You can see all of the blades and their function in the user manual.
The Bravetti KP80B food processor user manual can be read and saved from this website
http://www.euro-pro.com/europro/manuals/KP80B.pdf
If it's not there let me know and I will send it to you.
Rj
Sep 12, 2008 | Bravetti Quad Blade Food Processor
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
Jun 30, 2008 | Bravetti Quad Blade Food Processor
Bravetti Quad Blade Food Processor Logo
716 people viewed this question
Top Bravetti Food Processors Experts
Marvin
Marvin
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Bravetti Food Processor Expert? Answer questions, earn points and help others
