The frame of my top-load Thomson Washing Machine TX918 has dropped and the drum is stuck with clothings inside. I use the machine occassionally and it is defnitely not overloaded. The machine is only 2 years old. What is the problem and can it be repaired?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
