Question about Bosch Washing Machines
Please provide me a dimension and weight of the BOSCH ECOLOGIXX 7
Posted by Owen Pires on
Ngoro
    Top Expert:
  • Bosch Master
  • 2,620 Answers
Franco Dosil
    Top Expert:
  • 10,535 Answers
Https://www.devicemanuals.eu/wvh28420gb-bosch-automatic-washer-dryer-logixx-7/637/
Posted on Sep 27, 2019
Eric Taylor
    Master:
  • 590 Answers
Go online to the manufactures eric992
Does anyone have the specs for this model, HxWxD
Watts (W) 1300 W
Current (A) 12 A
Volts (V) 120 V
Frequency (Hz) 60 Hz
Tub type TallTub
Plug type 120V-3 prong
Dimensions & Weight
Overall appliance dimensions (HxWxD) (in) 34 1/8 '' x 23 9/16 '' x 22 7/16 ''
Required cutout size (HxWxD) (in) 34 1/8 '' x 24 '' x 24 ''
Product packaging dimensions (HxWxD) (in) 36 13/16'' x 26'' x 28''
Length inlet hose (in) 55''
Gross weight (lbs) 123 lbs
Net weight (lbs) 118 lbs
Of course you don't mention which model you have ??
Mar 18, 2016 | Bosch SHX68P05UC Dishwasher
Tip
8v Bosch Battery
Bosch Battery
18v bosch BAT025 BAT026 BAT160 BAT181 BAT189 battery, 3ah 3.3ah nimh.Note: NO Matter how many items you buy, the shipping cost is £4 only!!!!
2Pcs 18v BOSCH BAT025 BAT026 BAT181 battery 3.3ah nimh
18V 3.3Ah nimh Battery For BOSCH BAT025 BAT026 BAT160 BAT181 BAT189 (Postage: £4 only)
Battery Type: Ni-MH
Voltage: 18.00V
Capacity: 3300mAh
Color: Red
Dimension: 132.00 x 86.60 x 111.90 mm
Product Type: Replacement Battery (Brand New)
Warranty : One Year Warranty
Weight : 1427.28g
on Jul 20, 2010 | Computers & Internet
Ecologixx model WTD84560GB09. Why no heat?
The basic reason for no heat is failure of the heating element, be it electric or gas. Seems the "engineer" missed that.
Jan 29, 2016 | Bosch Dryers
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Ecologixx 7. Why does it keep switching itself off?
    could be the door switch has failed . try leaning on door when starting .
    Sep 13, 2015 | Bosch Washing Machines
    Bosch EcoLogixx 7 stays cold when running. Any ideas?
    First you need to make sure you have 220v comeing to the dryer..cause it will run off of 110v,,,but not heat intill it has 220v ..if you have 220v check the thermasate and the heating element
    Oct 02, 2013 | Dryers
    What are the dimensions of the Whirlpool microwave GH4155XPB?
    Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
    Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
    What are the dimensions of the bebecar m city?
    The details are as follows ;-
    1. Chassis folded size - 36.6 in X 20.5 in X 8.7 in
    (93cm X52cm X 22cm)
    2. Chassis weight - 25 lbs (11.4 Kg)
    3. Carrycot weight - 15 lbs (7 Kg)
    4. Seat weight - 13 lbs (6 Kg)
    5. Seat width - 13.4 in (34 cm)
    6. Handle height - 37-42.9 in
    7. Wheels - Swivel
    8. TSC - Yes
    Good Luck!!
    Thanks!!
    Aug 14, 2010 | Bebecar M City Stroller
    Is it heavy to handle?
    Dimensions & weight
    • Seat: 40 x 24 x 47 cm (WxDxH, H=backrest)
    • Dimensions chassis folded: 100 x 69 x 39 cm. (LxWxH) (including wheels)
    • Dimensions ready for use: 118 x 69 x 105 cm. (LxWxH)
    • Weight: 15.6 kg.
    http://www.babycare.nl/quinny-freestyle-3xl-comfort-black-p-102.html?language=en&name=Quinny%20Freestyle%203XL%20Comfort%20black
    Aug 24, 2009 | Quinny Freestyle 3 XL Stroller
    No hot water
    Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
    Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
    Washing Machines Logo
    342 people viewed this question
    Top Bosch Washing Machines Experts
    Marvin
    Marvin
    peter gittos
    peter gittos
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
