Question about Whirlpool Duet GHW9150P Front Load Washer
F06 and F14 error codes
I have the F06 error code as well. I just replaced the door lock (as I did 6 months ago with successful results) but this time I continue to get both F06 and F14 error codes. The door lock repair is quite easy. Unplug from the wall, remove the band spring on the door seal (20 in diameter or so), then remove the 3 Torx screws from the door lock (screws outside surface of dor lock) remove connections, remove & replace lock. RepairClinic.com for parts
F14 is a CCU (Central Control Unit) problem (or so says the Whirlpool manual), and I desperately need help. Anybody? Need a hand here. --Paul
Anonymous
    Problem Solver:
  • 16 Answers
Before you replace the control panel use a tester on the cable to check continuity .. if the cable is faulty you will get this fault
Posted on Aug 25, 2009
Testimonial: "Thx. All OK. I labeled all 14 cables, installed new one, and...success. It's said CCU relays could be culprit, and can be replaced for $4, not $240."
MrFixItDIY
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 21 Answers
Circuit Board Medics can rebuild the CCU for the F14 error and the MCU for the F06 error. The parts are upgraded over the factory components to prevent the errors from happening again. Find more details at www.CircuitBoardMedics.com.
Posted on Sep 14, 2012
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Tip
Continual electronic problems
I have spent a fortune on my machine getting door locks replaced, etc, but finally when the repair dude said I was going to have to replace the entire control panel the next time the machine wouldn't stop, start, lock the door, or whatever the ailment at the time might be, I took the top off, and manually checked all of the connections "under the hood". Machine worked and I have done this same thing five times in the last six months with the same results. With the way these things shake, they must loosen connections. It is worth a try, costs nothing, and I have had priceless success. Good luck.
on Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
I have a kenmore he3t quiet pak4 front load washer. First of dhl code. I ordered a new door lock and put that in. Then I got a f06 code. Put back in old lock and still only get f06 code. The other...
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its either a faulty MCU, or faulty drive motor.
Nov 03, 2014 | Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
Error code F29 continually reappears on our washer which is only 4-5 months old. We have tried to troubleshoot the problem, but have had no success. HELP!!!!!
Hi
Thanks for using FixYa. F29 is a door unlock error, this error occurs after the washer has made 6 attempts to unlock the door. Usually this occurs when the door lock mechanism is broken and/or the door switch/unit lock has failed. To resolve this issue you’ll need to check the door switch, door lock mechanism and the wire harness between the central control unit & door switch, replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,047 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
