Question about Sony MHC-GX555 Mini Hi-Fi System Shelf System
I need a part # for the volume controle on an Aiwa
I have an Aiwa cx-ZL31 shelf top system.
The volume control will only increase the volume. You have to press in very hard on the volume knob to get the sound to reduce. The remote still works fine, but I'd like to replace the volume control. I need to know:
1. Is the volume control a modular piece that can be disconnected from the system board.
2. What is the part number and where can I order the part
Posted by diamondes on
ABRsvcs
  • 4,234 Answers
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
Posted on Aug 24, 2009
lordFord
  • 175 Answers
Its sticky from debris, some are more susceptible than others. Dont order parts, you should be able to (using alchohol soltuion) clean the volume buttons.
I have 2 AIWA CX-NA303 volume can only be controlled from remote. Cassettes no longer play and doors won't open to remove them. Where are repairs available?
Search Results
    images for aiwa audio shelf systems service manual
    Free Aiwa Stereo System User Manuals ' ManualsOnline.com
    audio.manualsonline.com > ... > Aiwa > Home Audio Aiwa
    Products 1 - 50 of 107 - Aiwa STEREO RECEIVER User's Manual AV-S17. Pages: 0 Saves: .... Aiwa Compact Disc Stereo System Operating Instructions CX-NA22
Oct 21, 2015 | Aiwa Audio Players & Recorders
Aiwa cx-na 303
WHAT YOU COULD DO IN THE MEAN TIME IS, GO TO WWW,REMOTES.COM, PUNCH IN CXNA303 IN SEARCH BY MODEL, THEN GET THE MODEL NUMBER OF THE REMPTE, THEN GO TO EBAY AT WWW.EBAY.COM. TO GET THE REMOTE FOR CHEAPER, THEN IF YOU WANT TO REPAIR THE VOLUME CONTROL, FIRST, YOU WILL NEED A SERVICE MANUAL, CONTACT [email protected],in TELL HIM BRGARY3 SENT YOU, AND REQUEST A SERVICE FOR YOUR AIWA CXNA303, YOU WILL NEED A PAY PAL ACCOUNT FOR THE $9.00 PAYMENT, GO TO WWW,PAYPAL.COM, ONCE YOU HAVE THE SERVICE MANUAL, CONTACT AN ELECTRONICS TECH, HAVE HIM GIVE YOU THE PART NUMBER FOR THE CONTROL, THEN CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM CALL CUSTOMER SERVICE,ORDER THE PART, ONCE YOU HAVE THE PART, HAVE THE TECH PUT THE PART IN FOR YOU, THIS SHOULD SAVE YOU ABOUT $200.00.
Mar 16, 2013 | Aiwa NSX-A777 Shelf System
I need a replacement remote control for my old AIWA hifi mini system Model No CX-LEM50K
They do. If you're in the UK you can try Curry's Partmaster for replacements. Sorry to have to inform you that most replacement remotes are not cheap though, as the makers know when they can spot a money making thing. Everyone sits on or drops remotes!
Feb 22, 2013 | Audio Players & Recorders
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very muffled. The sound is fine if I have it on cd or the radio but when on Aux Video I can barely here it.
On most TV's with speaker control there's a way to disable the TV's volume control effect on the level fed out to an external amplifier. Find it and disable it it or select FIXED for its level, or, while listening through the Aiwa, raise the TV's volume through its own remote and see if that affects what the Aiwa gets for volume.
Or, enable the TV's speakers but find the same interna lAudio setting and make it Fixed, but turn the TV volume down if you don't want to hear its speakers. That way, you could actually listen to the TV on its own speakers if you want, say, for casual watching of the Weather Channel or news, for example.
Nov 28, 2009 | Aiwa NSX-DS55 CD Shelf System
The clock on my shelf system cx-naj20u went to 24 hour mode. How
To switch to the 24-hour standard
Press CLOCK while pressing SHIFT on the remote control and
then press S within 4 seconds.
Repeat the same procedure to restore the 12-hour standard.
Apr 04, 2009 | Aiwa NSX-AJ20 CD Shelf System
AIWA shelf system volume button
I'm sorry but I don't have a listing for that model number. Many of hte Aiwa units use what is called a digital encoder. A call to Sony with the model number should get you the part number as well as the cost and availability. Aiwa is a brand of Sony.
Dan
Dec 15, 2008 | Aiwa NSX-DS55 CD Shelf System
AIWA products
Download User Manual for Aiwa NSX-AJ50 Hi-Fi system.
Sony owned Aiwa few years back and you can see NSX-AJ50 page on Sony Support.
If you have Aiwa part Query, please contact nearest Sony Service center.
Oct 04, 2008 | Aiwa NSX-AJ50 Shelf System
Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
579 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
