The televisoin works fine the picture seems ok but their are these lines that go horizontally across the screen that arent to noticable but as u change the channel the screen is red with the horizontal lines, is something just out of allignment?
If its a kp-51hw40 : go to an unused video input and look at the screen---if it is redish in the background with curved faint trace lines you have one of two things wrong; First: the red "screen" control may be set too high. Second: you may have a problem with the RED picture tube.
To try to adjust the RED screen down you have to remove the entire front grill plate on the front of the TV(some have screws on the back on either side that have to be removed---and then you should be able to pop it out. Behind it there is a masonite inspection plate held in with screws----Once you have that off look for a SMALL SQUARE BLACK PLASTIC BLOCK; it has 6 black adjustable controls---you have to use a flashlight and look carefully---one row left to right will be marked FOCUS--DON'T TOUCH THOSE---THE OTHER ROW left to right will be marked SCREEN; if you look carefully you will see marked by each r (red) g (Green) b (blue)
you want to locate the RED SCREEN CONTROL.
WITH the set still on a blank video input where you can see it clearly turn the RED Screen Control to the left until the lines and red tint go away---do this slowly and make sure you are adjusting the RED screen--not the FOCUS.
IF this has been helpful give me a vote here as I do this for free; yesterday I adjusted one of these in a home that was blue with the faint lines---about 15 minute job for me.
if you have questions or need help:
[email protected]
