Question about Sharp Office Equipment & Supplies
Sharp AR-R550n Please i have Sharp AR-M550N with error code E7-03. I have replaced the HDD. Do i need to reset the code. If yes, Pls how?
Posted by Inter-communications on
Everett Lin
    President:
  • Sharp Master
  • 990 Answers
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
Posted on Aug 23, 2009
ERROR CODE F2-00
Please you should replace your toner cartridge.If you have new toner cartridge than the chip destination error.Thanks best luck
Apr 18, 2013 | Sharp - AR-M550N copier - ARM550N
Sharp AR-M550N close the upper left side cover
Close the lower left side cover error :
this problem is for under the left door
for fix this problem push the all part on left side
under the door is important
mehdi ebrahimi iran,karaj
Oct 19, 2012 | Sharp AR-M550N Copier
Error f5 05 en copiadora sharp
I know to fix this problem.But I need money.If you are agree to pay 5usd by my PayPal account .please send to [email protected]
Mar 02, 2012 | Sharp - AR-M550N copier - ARM550N
Sharp AR-M Error CODE E7-02 - How can I fix this?
this is occur due to LSU (laser diode,reception element,apc circuit )trouble or LSU drive circuit (asic) trouble.
1.first go to service mode (simulation mode)& reset it
2. still error occurred, check wire harness of laser unit & clean laser unit mirrors,reflector polygon mirror.
3. still occur just replace toner cartridge because once it works for me.
4. finally replace laser diode.
May 24, 2011 | Sharp AR-M550N Copier
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
Is it possible to "lock out"trays 3 & 4 on a Sharp AR-M550N, so they can not be used by everyone? If so, How?
Yes, in user settings. Under paper tray settings. I don't know why you would.... But you can also change the paper size to a odd ball size too.
May 11, 2010 | Sharp AR-M550N Copier
Reducing on an AR-M550N
You can download a manual from http://www.sharpusa.com/~/media/813980603C1E4072A9071108E8971025.ashx?cop_man_ARM550_620_700.pdf
Jan 05, 2010 | Sharp AR-M550N Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Oct 06, 2008 | Sharp AR-M550N Copier
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
289 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
