Question about Creative Labs Zen Nano Plus MP3 Player
When i record songs it's all one track
I hooked it up to my cd player and and did the mp3 encoding and when it was done it was all one track. am i doing somthing wrong?
  • 820 Answers
The guide for Zen nano plus:
http://files2.europe.creative.com/manualdn/Manuals/TSD/8899/0xBA9C626B/Zen%20Nano%20Plus%20Quick%20Start%20Multilingual.pdf
It seems that pauzes between the tracks do not seperate them into
split up songs onto the player.
Support for Zen nano plus on this site:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&subCatID=214&prodID=12720&prodName=ZEN%20Nano%20Plus&subCatName=ZEN&CatName=MP3+Players
You can rip audio CD using:
1. "application software" (getting a download from the support site) or
2. Windows Media Player 10 or 11 (WMP11 preferred).****
2.1 ****When making connection with the correct database,
songs will get the corresponding MP3 tags / names.
Posted on Aug 23, 2009
6ya staff
SOURCE:
Why would the output sound level on a MP3 vary so much?
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
Nov 11, 2017 | Audio Players & Recorders
If I want to record let's say someone speaking for 90 min and burn 2 cd's , one 60min and the other 30 min from the one 90min recording , each one divided into tracks , how would I do this ?
If you want to burn a CD you have to make a master. For 2 cd's you have to make 2 masters, one for each recording.
The best way to handle this is to "create a song" for each speech giver and give each a name.This is because you can make only one master copy of a song before burning a Cd.
But another way is to :
1. Make a master of the first speech giver (who is on one track) and record to the Cd.
2. Make a new master of the second speech giver (on the other track) and record to Cd.
As long as you don't mind, the second mastering will overwrite the first one that you did, but then you already have burned a copy of that Cd!
Nov 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
No Valid Tracks or No Song Select
You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
Feb 14, 2010 | Marantz CDR420 CD Recorder
On all tracks when i press play i get message ''media engine error! drm license not available'' i have a gogear sa1942
Your song (.WMA) are copy protected by 'Microsoft Windows Media digital rights management (DRM)' and appears to be requesting a license key which needs to be loaded to your player.
Solution:
- Media Player will automatically load those licences keys to your player for your authorised music/media files.
- Alternatively, remove DRM (for song that you own ...) by some third party means software (including burning them on CD with appropriate options)
- Use alternative songs encoding (such as .mp3) that do not this protection.
Dec 28, 2009 | Philips Audio Players & Recorders
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
Deleted all songs from mp3
i have formated my Ipod and the songs present in it were deleted and now it can not play any other song. Should i convert songs to ipod . and how can i convert?
Feb 26, 2009 | Creative Labs Zen Nano Plus MP3 Player
Bad Tracks
Ouch !
can you say FORMAT ? lol
This is the exact situation I've been talking about , make sure that you check each file with an mp3 encoder checker such as encspotbasic 2.0 before loading them to the E260.
you could try MOVING the bad tracs , instead of delete , and you can try to OVERWRITE the bad tracs with a fresh copy of the file ( one checked with the encoder checker )
these silly methods may or may not work out , let me know what happens.
Shalom >:D<
Sep 09, 2008 | SanDisk Sansa e260 MP3 Player
Loading songs - format message
if you've used wmp to rip and encode the cd to the wma file standard, the ipod won't play them. the ipod doesn't support wma or ogg vorbis (and doesn't support the pro part of mp3 pro) you need to encode your files to either mp3 or aac (or leave them as wav files, though these are very large) for the ipod to play them. this may be causing the mmjb transfer problems.
check out the software compendium on info on alternatives to rip, encode and transfer to the ipod.
Jan 09, 2008 | Apple iPod shuffle MP3 Player
MyMusix PD-6110 MP3 Player
When you hook it up, you should see an icon on your computer for the MP3 player.
I download songs from iTunes to my MAC, then drag them to the MP3 player. However, they do not come from i'Tunes in a MP3 format. I found this on the internet for how to change the format:
When iTunes is open, find "preferences" and then locate "importing" (just look around on the different tabs till you find these, since Mac and Windows put them in different spots) tell it to import using MP3 encoder from the drop down bars, and say OK. now you can right click on the song you want to convert and select "convert to mp3".
Then drag the MP3 song to the MYMusix player icon and it should copy the song.
Dec 26, 2007 | MyMusix PD-6070 MP3 Player
Creative Labs Zen Nano Plus MP3 Player Logo
91 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
