Question about Magic Chef MCBR440 Compact Refrigerator
My mini fridge will not work. compressor is hot.
I Have a Magic Chef Model # MCBR445S that doesn't work and the Compressor is hot. I do have a tester.
  • Anonymous Mar 24, 2014
    What is the button in the middle of the temp gage on a magic chef mini fridge?
  • Pamela Evans
    Pamela Evans Jul 09, 2018
    I have the same problem and can't find a replacement relay switch?
John Tripp
  • Magic Chef Master
  • 4,656 Answers
Believe you need to change the start relay and overload, Sea Breeze
Posted on Aug 27, 2009
My magic chef mcbr445s will not cool down the compressor NSA30la cg stays hot what should i change out
check the condenser fan if working good or clean you condenser unit use water from faucet
Feb 24, 2011 | Magic Chef MCBR445S1 Stainless Steel...
My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Aug 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
My mini fridge will not work. compressor is hot. thanks
The first thing that I would look for is a defective start relay and start capacitor. If you are ready let me know and have a ohm meter and we can do some test. Sea Breeze.
Jun 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
3,153 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
