Question about Coffee Makers & Espresso Machines
HB brewmaster model 47374 will heat but does not circulate the water so as to make coffee. any advice? thx in advance
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Coffee lukewarm
If this Christmas, it should still be under warranty. Contact HB for return / replacement.
Posted on May 16, 2008
Anonymous
SOURCE: I cannot get the coffee to pour out!!!
I calleed the 1-800 number for help and they said I would have to purchase a new tank...no thanks, I can get 5 years from a $10.99* MR. COFFEE AND ONLY ONE YEAR FROM THIS ONE????? ...so much for standing behind a product !!!!
BARB
Posted on Sep 29, 2009
What are the instructions for preheat after turning our bunn coffee maker off over night - there is not off switch, plug in only
* Bunn model # for specific solutions.
* Most Pro/Office models have a pre-heated tank.
* Most models (Without Vacation or heater switch) will be heated all the time.
* Care must be taken to keep the inner tank filled.
* Pour cold water into fill tray till water comes out of the brew basket.
* Water will stop coming out of brewer once the tank has been topped off.
* If pot is not able to brew after 20 mins of pre-heating. Then call for service.
* Note; most office and Pro machines used in food establishments are from coffee vendors. The larger machines should be serviced by qualified Bunn service techs.
* Contact your coffee vendor or Bunn service ctr for advice.
Aloha, ukeboy57
Sep 05, 2018 | Bunn Coffee Makers & Espresso Machines
HB flex brew model 49995R doesn't brew a full cup of coffee
If it is only 3 weeks old, then dig up the receipt and return for an exchange.
Mar 02, 2015 | Coffee Makers & Espresso Machines
Hamilton Beach Brewmaster 47374
The problem is the plastic valve on the bottom of the tank. If you remove the 4 screws connecting the black and white parts together it will expose the valve and you will find that at least one of the tabs that secure the valve are cracked off. You can replace the tank for a new one at HB website for 10 bucks or try to repair the valve yourself.
Apr 23, 2012 | Hamilton Beach BrewStation 47224 Coffee...
V'Espresso makes hot water and steam, but does not release water into brewmaster. Only makes loud noise.
Sounds like either the grind is too fine or the brew unit is blocked at the shower screen.
If the coffee ground discharged are wet, then the grind is too fine, if they are dry then the upper screen needs to be cleaned because it is blocked with coffee oils.
Nov 29, 2010 | Saeco Coffee Makers & Espresso Machines
BARB
Sep 19, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Saeco Vianna DeLuxe - Can't get the gearshaft to align
Hi Your brew drive has passed the micro switches that change the direction of the drive when activated. They also might be damaged. Your solution requires you to remove the top. If you think you are capable of attempting this contact me and I have directions.
Jun 08, 2009 | Saeco Incanto Classic Espresso Machine
Model 47374
you can buy a new tank from hamilton beach.com its about 10 bucks
Jan 24, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton beach brewstation
I found this site that calls it a "permanent dispencing filter" but the small print says that it is the small domed filter that sits on the bottom of the tank so I sounds like the same as the filter screen. FYI, there is a pricing conflict when you click on the part. The part link shows that it's $4.99 but when you select the part or try to order it, it comes up as $5.99. Here's the link http://abtecparts.com/hamilton_beach_brew_station_filters.htm
I will probably still call HB tomorrow and see what the want for it before I buy.
Jun 01, 2008 | Hamilton Beach BrewStation 47214 Coffee...
FixmeBob Great help with Breville 800esxl
I had a similar problem, but no blinking light, only cold coffee. I tapped on the relay (black box on circuit board) and violá.  Red light, hot coffee, and happiness.  The machine did the same thing a couple of weeks after the "fix", and a good slap to the left side, and I was back in business.  My guess is that your switch is bad or sticking.  Good luck.
Feb 06, 2008 | Breville Die Cast 800ESXL Espresso Machine
Coffee lukewarm
Jan 07, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Coffee Makers & Espresso Machines Logo
53 people viewed this question
Top Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Pierre Laplante
Marvin
Marvin
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
