Refrigerators Logo
Question about Kenmore Refrigerators
Kenmore elite side by side ice maker arm freezes in down position
Arm develops ice sickle which keeps arm in the down position....
Posted by John Smith on
5 Related Answers
Anonymous
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
Anonymous
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
Anonymous
  • 1314 Answers
SOURCE: ice maker arm
you can take out the screws that hold the ice maker to the freezer wall unplug the ice maker take off the front cover remove the four screws holding the motor module which is brown take that off and reattach the shutoff bail arm and reassemble. their is a gold forked metal piece in there the bail arm has to be in that fork .or you can replace the ice maker
Posted on Jan 09, 2008
Anonymous
SOURCE: Ice maker grinding sound
I had the same and found the same solution. Chances are the problem will come back. Just over a week ago (when it was freezing cold in Florida) I took everything out of the fridge and freezer, unplugged it, even pointed a hair dryer in the ice unit. Once I was done it was completely defrosted and dry. I have not heard anything since - and I can sleep again ;-).
Posted on Nov 05, 2008
Anonymous
  • 1136 Answers
SOURCE: ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Posted on Jul 12, 2009
We have a 7 year old Kenmore Elite trio. The ice maker continues to make ice, but won't dispense it. It appears that the plastic ice shut off arm is stuck in the up position. How can I get it unstuck
Most arms on ice makers are metal.
You might have to take the food out of the freezer temporarily and put the food in an ice chest and disconnect the refrigerator and let it unfreeze the plastic arm.
1helpful
Ice maker won't stop making ice. We put the metal flip facing up and it just keeps making ice. It should stop...right?
If the arm is up and locked in position, it should stop the ice maker. check that the bail arm is indeed pushed into the ice maker head, you will likely have to remove the ice maker with the 1-3 screws holding it in place, to see it. Check also that the other end of the bail arm is attached near the fill cup, if its not attached, that could be the reason. If the arm does not appear to lock in the upright position, or if it does and still does not stop ice production, you will need to replace the ice maker
It seems to me that the sensor arm on the ice maker should be down until the ice bin fills up, but the arm on my fridge seems to be stuck up in the ice maker. How can I resolve this?
you are right the arm must be in the down pos to work properly . if it will not come down by pulling is down then the head is bad or some plastic arm inside the head is broken . in either case the head will have to be replaced .. the arm should easly be able to raise up and click in to pos and then down . mm
Ice maker is not working
check that the ice maker arm is not in the up position or has come dislogded. if the metal wire is dislodged use a mirror to help put back in the ice maker. put it back in the round white area with an elongated slot. flip down if off. check the ice maker to see if an ice cube got hung up and is jamming it. check with eyes and fingers. last the ice maker will not cycle if the door switch is not activated. this check requires you turn off the ice maker with the arm. come back in 6 hours put the arm back down and hold door switch and see if it starts.
Ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Ice maker is not making ice
Ted,
The arm should be down. The down position applies power to the control module... when the arm is up power is off. It's the opposite of a light switch.
SG
2answers
WATER WILL NOT GO INTO ICE MAKER. BUT IT DOES DISPENSE THOUGH THE DOOR
hi. thanks for the question. first is the arm on the ice maker up. or down . should be down.On the back of ice maker, a small tube, that lets water into the ice maker .sometimes it can freeze up .not allowing the water to flow ,in the ice maker .check that. the next check, is the water valve behind the fridge ,at the water source. thanks the appliance doc
Kenmore elite, will not make ice, but it does dispeanse, when i put bagged ice in it..
hi thanks for the question is the arm by the ice maker in the down position is the arm even there if that's ok you could have a problem with the water valve for the ice maker thanks the appliance doc
17helpful
5answers
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Open Questions:
Top Kenmore Refrigerators Experts
Dennis
Level 1 Expert
tina gallow
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
