Question about Canon EOS-AE-1 35mm SLR Camera
Battery Pack Stuck In Camera
I Just Got A New Olympus Stylus7000 Camera I Put In The Battery Pack And When I Tried To Get It Out It Does Not Come Out HELP
Posted by komal_rox on
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
Olympus E20-N will not turn on.Olympus E20-N
what battery pack? extended (using the b-12lpb) or conventional?
can you read the battery condition before shut down? (%)
Jun 02, 2009 | Olympus FE-230 Digital Camera
Sir My camera's( olympus stylus-1000)batery is in trouble. could you please give some authorization service centers in Cochin , Kerala, india. Your"s faithfully subhash
"sir
My camera's( olympus stylus-1000)batery is in trouble."
Hah! I love that! Not making fun or nothing, but many people aren't as polite to put "Sir or Madam" before writing things down. Very polite. :D
As for your battery; it'd be easier just to buy a new battery pack from off the internet, as repairing a battery pack would be impossible, or cost as much as buying a new pack itself.
Nov 30, 2008 | Olympus LI-12B (200838)
Power on
I have same problem, Im gonna to try put a regular charger,then wi will see
Jun 20, 2008 | Olympus SP-350 Digital Camera
Lens is stuck so Camera does not turn on
The battery packs in these units dont have a very long "shelf life" meaning when you charge the battery you need to use it within a few days or it will loose charge. Have you tried a fresh charged battery? They are very power hungry devices and the more advanced they get the more power they need. How old is this unit? how many charges have you put on the pack? it may be time for a second pack. An emergency backup pack good power is key nowdays.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Type of batteries
Olympus recommends the use of Nickel-Metal Hydride (Ni-MH) rechargeable batteries or Olympus CR-V3 (LB-01) long-life disposable lithium batteries. The batteries are only used to power the camera. The print engine in the C-211 Zoom is powered by a battery pack self-contained inside each Polaroid® Type 500™ film pack.
Sep 01, 2005 | Olympus Camedia C-211 Zoom Digital Camera
Canon EOS-AE-1 35mm SLR Camera Logo
Top Canon Photography Experts
old marine
old marine
Jax Planet
Jax Planet
Are you a Canon Photography Expert? Answer questions, earn points and help others
