Question about Jensen VM9510 Car DVD Player
Mute won't go off jensen
Mute stuck on my jensen vm 9311ts
Posted by mozsubs on
Anonymous
    Problem Solver:
  • 10 Answers
Mute switch on ur car dvd is broken
Posted on Aug 23, 2009
My jensen cd player model 9311ts will not let me insert a cd yet the screen reads no disk
try to use clean n shiny disc (scratch less Cd), if it won't work, try to clean the optical lens with Cd cleaner, if it doesn't work either, you might need to replace the optical lens of the Cd player
Apr 10, 2010 | Car Audio & Video
I have the vm 9311ts how do i bypass to watch movies while i drive
I have the same head unit in my Audi. Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Sep 04, 2008 | Jensen Car Audio & Video
Stuck mute
I had the same problem. Deatache the mute wire. That is for cell phones. I think it is the brown wire but I cant be sure. Look over the wiring diagram and it will say Mute. Don't wire this wire in.
Feb 06, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9311ts media module
I have the Jensen VM 9311ts. Where can I get a media module for it? I found the cord and the j link cord , but I can't find a media module anywhere. HELP!
Jan 08, 2008 | Jensen VM9411 Car Video Player
In dash
I don't think you can - it's likely that it's an LCD-type screen illumination, not bulbs that can be changed. I haven't yet heard of anyone able to do this. I wish it was possible though - I have the 9311TS in my Audi, and the Audi uses red dash illumination.
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Need Help with a 9311TS - viewing movies while the car is running
hi, i just bypassed my 9411 by doing the following. put dvd in the player wait until it loads,then push the stop button 2 times on the remote push 1264, on the right button push it twice down and in once...this should take you to the system setting there you want to turn off the brake overide on..push the left button once or just wait for the screen to return to the movie....I hope this works as good as it did for me...let me know.....later
Feb 13, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
187 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
