Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
My Jazzy 600 wheelchair will not move. The lights on joy stick are blinking. It blinks with four yellow lights, then it blinks from left to right with the whole amount. Can u tell me what to do?
The turn off button stoped working long ago. I just leave it on. The fast button fell off last month, but I use screwdriver to speed it up. I'm 72 , widow , can u tell what I should do?
Posted by Shelia Dix on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Chevy Cavalier 2001 turn signal blinks fast
If new bulbs don't work, it is probably the harness that holds the bulb. I had to replace both on my car after fighting with the problem for over a year and not knowing.
Posted on Mar 19, 2009
Anonymous
  • 32 Answers
SOURCE: jazzy wheelchair 1170....left side stops and sticks,.
those codes 1 light flashing and 2 lights flashing refer to a left and right motor fault respectively....expensive repair
Posted on Apr 03, 2009
Curt Downs
  • 1779 Answers
SOURCE: 1998 ford taurus left turn signal blinking fast
Replace the bulb that stays on and doesn't blink, if that doesn't solve the problem, let me know.
Posted on Apr 13, 2009
Anonymous
  • 321 Answers
SOURCE: left rear turn signal light on my 1999 chev. s10 is not working
any increase in bink speed is direcly related to a bulb being burt out.
Posted on Jun 12, 2009
spacholke
SOURCE: When you turn wheelchair on, all lights(red,green,
anti theft. while the lights are flashing, hit the horn button twice.
Posted on Oct 05, 2009
My mother have a pride jazzy serial j-913718 joy stick blink and keeps blinking, I tried what is sugested for the model 1103 but no reults, could someone please help me
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File to read via an Adobe Reader.Hope this was of help,Colin.
Nov 23, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
How do you hook up to charge a jazzy 600 wheelchair
your charger plug fits under the controller joy stick. It has 3 coverd prongs [email protected]
Nov 18, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
