Want to use earphone jack to transmit bluetooth via transmitter
SOURCE: audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
SOURCE: low transmit audio cobra 29 ltd nw
Hey Tim, Hook your radio up to a fairly nice modulation meter, and check the output on the meter. If it's below 100%, then adjust VR-4 until you get 100% output. Do not use anything metal to adjust it with. As metal drivers and ect. will give you a false reading, and if you slide off the varible by accident, it could blow your radio.
Get It Done!! J.R.
SOURCE: In recent days my headset (590A) has only been
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
SOURCE: SHC5100 Earphones-plugging jack from transmitter
Hi' According to your problem first make sure the jack or the cord
is not faulty. Check the battery & recharge it. You may need to change the
battery. After charging Install the antenna tube into the transmitter properly then turn
on the transmitter. After that connect to the TV within range.
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
