Question about Radio Communications
My AltaHR will not connect to my iPad. I have turned Blue tooth off and on as well as my iPad. The Alta is charged. I do have to wear it on my dominant arm.
Posted by Nancy Scott on
1 Related Answer
Vladimir Frolov
  • 2075 Answers
SOURCE: Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Posted on Feb 09, 2015
I have the Logitech keyboard and iPad connected the blue light is flashing and I had charged the keyboard last night when I attempt to connect the blue tooth it states connection unsuccessful
The keyboard should have no problem, but you need to look at the ipad's bluetooth and have it search for the KB. The KB will only attempt to connect for a few seconds, then you need to press the seek button again, or turn off/on to restart the search.
Apr 21, 2018 | Logitech Computers & Internet
I have installed the adapter internally in the printer but my ipad doesn,t detect it what else do I need to do
Make sure the blue tooth adapter is set to "discoverable". Then open your blue tooth app and search for connections. You should be able to find it. After two minutes, if it does not find it, turn printer off, restart ipad. Try again. good luck
Mar 07, 2015 | Canon BU-30 Bluetooth Wireless Adapter for...
Feb 08, 2015 | Logitech Ultrathin Keyboard Cover
My shark keyboard for iPad air does not pair for blue tooth operation
Perhaps you look on this link to see you did everything right, like charging the battery, switching on and pairing. Don't forget to switch on bluetooth on your iPad. SHARKK Apple iPad Air Wireless Bluetooth Keyboard Case
Sep 10, 2014 | Apple iPad Tablets & eReaders
Zagg keyboard doesnt work
Mine went dead after about 3 weeks. Once I realized there was a charging port which is not IPhone, but droid type. Began charging. Would not recognize until I went to blue tooth setting and said forget device. Then turn bluetooth on and then hold bluetooth key down on for 3 seconds or so on keyboard. Then it worked. I guess dont let it run till it dies.
Apr 16, 2013 | ZAGG New Apple Ipad 2/ Brand New Ipad...
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
Trying to connect I Pad to key board through blue tooth
Sometimes Bluetooth devices connect better if they are not too close to each other, so separate them by a couple of feet to see if that helps. If the keyboard is charged and turned on, do you see any lights blinking on the keyboard? there should be some indicator lights if it is working properly. In your Bluetooth settings on the iPad, does your keyboard appear under Devices? If it is listed, click on it to start making the connection. If that doesn't work, click on the arrow to the right and 'Forget this Device'. Turn your pad Bluetooth off then back on and try making the connection again. Often the forgetting process and rediscovering can fix a connection problem. If none of these work, try searching your keyboard brand and model at apple's support discussion for iPad community to see if it is compatible or other people report the same connecting problem. Bluetooth is funky, i've been in an Apple store and could not connect to a Bluetooth device that apple sells in their store, although the store employee could connect his iPad to the same device, we couldn't get mine connected. Good luck!
Dec 15, 2012 | Apple Ipad 3rd Generation 32gb Wifi 4g...
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
Radio Communications Logo
119 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
