I also have a cybershot only mine flashes "E:91"01" and will not flash, ever.
Hi!
The error E:91 indicates a hardware malfunction in the Camera. In this case, you may try resetting the Camera to the original factory settings.
Follow the steps given below to reset the Camera to the original factory settings:
(a) Press the Menu button to display the menu screen.
(b) After pressing the right arrow on the control button, go to the (setup) setting, then press the right arrow again.
(c) Next, press the left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" option OK, OK.
(e) Set the clock if date and time screen appear.
(f) Next, turn off the Camera and remove the Battery pack and press and hold the power button for 30 seconds.
(g) Then, reinsert the Battery pack and turn the Camera ON.
Performing all the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, please check the operation of the Camera.
If the Camera continues to display the error E:91 then service will be required.
Regards,
Pacific.
